It is currently Sun Feb 15, 2026 8:47 am
Reply to topic  [ 9 posts ]
 31 vanguard speed
Post 31 vanguard speed
I am about to buy a 31 vanguard inboard mudboat on a haul about 14-16 ft. long. It has a clutch! I was wondering what the average speed for the boat should be and what could i do to make it go faster?
Sun Nov 01, 2009 6:30 pm
Post Re: 31 vanguard engine help
I think you are asking what kind of speed can you expect from a 31 short tail on a 14-16ft boat.
If so, I would say low to mid 20's.
Want more speed, you'll need to buy some of the aftermarket parts.
You can go as fast as your pocketbook is deep.
Mon Nov 02, 2009 9:49 am
no its not an outboard its an inboard engine
Mon Nov 02, 2009 9:01 pm
Post Re: 31 vanguard speed
then its a mudboat. I know my buddies mudboat with a 27 kohler only went around 18 and it was a 1438 skiff. Your prolly looking around the same with the bigger hull
2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR
Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
Mon Nov 02, 2009 9:20 pm
PM Coodik he just finished one I believe it was that size a few days ago.
1754 GT EXTREME 37EFI
Mon Nov 02, 2009 9:28 pm
Your speed will depend on the clutches gear ratio also.
Mon Nov 02, 2009 9:45 pm
That was my motor that Coondik just finished up. My boat is a Machete (Super Godevil) type unit. The stock 31 with a new prop light boat I could get 23-25 with no wind or current, 18-20 with a hunting load. If you have the ZF transmission and it has a left hand rotation prop you are looking at 1.8:1 reduction, right hand rotation is 1.4:1. I am running a 12x14 Hopkins cleaver (LH rotation) with alot of cup and tip curl. I'll assume if you set it up like a regular mudboat you would run a regular mudboat prop since the prop won't run on the surface. The engine work I just had done was shave the heads, SS valves, timing advance, 36 intake and carb, K&N filter and dual exhaust. I'm swinging the crap out of my old prop, Hopkins is currently building a new prop to match up to the engine mods I had done. I'm not really counting on much more top end but I think my load speeds will be better. One thing I can tell you, my motor never idled and ran so smooth. That Coondik dude is the man!!!
Tue Nov 03, 2009 10:50 am
if ur turning the old prop too much, the new prop ur getting, assuming it's either bigger in dia or more pitch/cup, should bring down the rpm's and bring up the speed.
that is unless it's too much prop, then u will have to wear it out sum to be able to turn it.
good luck, those machete's are a nice rig. :)
Tue Nov 03, 2009 12:34 pm
i ran mudboats all my life, most people i know still do, i would say mid 20s
Tue Nov 03, 2009 9:32 pm
