flint87
 Empty boat trailer.
Got abt a 450 mile haul with an empty trailer tomorrow. The son of a bitch likes to bounce too. I found some heavy scrap steel around the farm to strap to it and it seems to work but after a 10 mile drive the shit has come loose already. I have a 15 foot boat I could stick on the trailer but I'm picking up a hull down there and don't know how compatible they would be to stack and if it might damage one hull on the way back. Any thoughts? Should I just let it bounce? Part of the trip involves that piece of shit they call I-10...
Thu Jan 15, 2015 2:41 pm |
butternut
Joined: Tue Nov 12, 2013 9:30 am Posts: 770 Location: EAST ARKANSAS
 Re: Empty boat trailer.
30 to 50 gallon plastic barrel with water in it.
Thu Jan 15, 2015 2:46 pm |
Paulox86
Couple of fat chicks?
Thu Jan 15, 2015 2:48 pm |
butternut
Lay the barrel on runners above the axle fill with water until it runs out put cap on and tie downs.
Thu Jan 15, 2015 3:03 pm |
flint87
Thu Jan 15, 2015 3:17 pm |
flint87
Thu Jan 15, 2015 3:18 pm |
butternut
that's what I did when I run from Arkansas to LA at gator trax.
Thu Jan 15, 2015 3:30 pm |
flint87
I can screw a board down to the bunks in front of and behind the barrel to keep it from sliding
Thu Jan 15, 2015 3:31 pm |
butternut
Empty most of the water out when you get there and load it in the back of you truck.
Thu Jan 15, 2015 3:35 pm |
flint87
Thu Jan 15, 2015 5:13 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
Fill it full
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
Thu Jan 15, 2015 6:29 pm |
butternut
Thu Jan 15, 2015 6:36 pm |
flint87
Well this will work out good but the only barrel I could find has a little motor oil in it. I don't wana go dump used motor oil from Georgia on the ground in Louisiana.
Thu Jan 15, 2015 7:28 pm |
flint87
Might just have to let this bitch bounce and hope she hold together
Thu Jan 15, 2015 7:29 pm |
SETx Longtail
I have taken 8-10 cinder blocks and strapped them to an empty boat trailer. It helps but it'll still bounce some. Easier to tie down than a barrel. Put as many as you can on the bunks, should be fine. Stack them in the truck for the ride home.
_________________ #CFFITR
Thu Jan 15, 2015 7:41 pm |
butternut
roundup barrel
Thu Jan 15, 2015 8:57 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
_________________ You have your whole life to be an idiot, take a day off!
Thu Jan 15, 2015 9:15 pm |
flint87
Thu Jan 15, 2015 9:19 pm |
Paulox86
Go to a local carwash. They usually have 20-30 plastic barrels waiting to throw away. And they hold biodegradable chemicals.
Thu Jan 15, 2015 11:40 pm |
butternut
Fri Jan 16, 2015 8:35 am |
prodrivinggatortail
Fri Jan 16, 2015 10:02 am |
mo_ducker
_________________ 36 PD 1850 VooDoo custom by Dfou
Fri Jan 16, 2015 11:51 am |
Russ
Fri Jan 16, 2015 10:53 pm |
petrel
Joined: Mon Jan 11, 2010 9:51 am Posts: 770 Location: NVA
Quickrete tube sand.
_________________ Phowler 2066 w/ E5 37 ProDrive w/ Illowa Marine Heads MoMarsh Fatboy/2 Honda
Sat Jan 17, 2015 4:04 am |
flint87
Update: didn't want to dump used motor oil in the ground. Wound up strapping the scrap metal on real tight. Made it from Atl To nola in tact. Now the boat is loaded and I'll be headed home tomorrow, decided to spend the weekend here. Thanks for the input guys. I know the water barrel would've worked had I had a clean one though.
Sat Jan 17, 2015 10:54 am |
