It is currently Sun Feb 15, 2026 10:58 am
Reply to topic  [ 13 posts ]
 homebuilt short tails
Post homebuilt short tails
hi all this is my first post on this forum so howdy :D
i have recently built an 11 hp tecumseh longtail, using mostly parts from home depot and some online sources for seals and bushings. (mcmaster-carr is awesome) anyway, i would really like to join the group here eventually with a higher horsepower motor that can really haul tail. seeing as there is no search on this forum (a recommendation) i would like to be able to see what others have done, even the dealers. some of my main interests are 3 gear transmissions, and shaft angles and lengths. im a big fan of building my own equipment seeing as i only spent around 1 grand for my motor, which a lot was wasted due to not knowing what i was doing. sorry for the long post, but i would just like to pick the brains of some of the home engineers out there, thanks
fishon!!
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Tue Nov 17, 2009 7:11 pm
Post Re: homebuilt short tails
Tue Nov 17, 2009 7:14 pm
Welcome to MMT! :mrgreen:
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Tue Nov 17, 2009 7:26 pm
welcome ma baw.. dis site will def. help u find out what u need to know. creative thinkn like that is how da surface drives came about in da first place soo.... good luck ;)
1648 w/ a 36 pd fpr on dat biatch
G-14 CLASSIFIED SKIFF ON DA WAY!!
Never try to educate someone who resists knowledge at all costs.
Tue Nov 17, 2009 7:30 pm
aaawwww :oops:
-1436 flatbottom
Tue Nov 17, 2009 7:32 pm
I built a small 13 hp shorttail a few years ago. If you can weld aluminum and build a longtail, you won't have too many problems. I stayed simple, no clutch and manual trim. Let me know if you have any questions. I have many hours of research into it.
Mag10
Wed Nov 18, 2009 12:42 pm
Wed Nov 18, 2009 6:52 pm
ok i posted pics in another thread. i couldn't find any threada on building short tails, so if someone knows of one please let me know, thanks much
-1436 flatbottom
Wed Nov 18, 2009 7:36 pm
Sorry, about the picture quality.
PM me your email address, and I can send you sketchs/plans that I put together.
Mag10
Thu Nov 19, 2009 4:36 pm
Hey bro thats looks cool how fast does she run.
1746 with a modded 35 gdsd
Capt Team total asalt
Thu Nov 19, 2009 6:30 pm
It runs about 15 mph on a riveted 1436 jon with 2 lighter guys in it. I built is initially, with a 9X6 subsurface prop. Never got around to running a 10X8 surface piercing prop, but I think it would have swung it. It has a 1.5:1 reduction. May have stepped the speed up a little bit. Fun project.
Mag10
Fri Nov 20, 2009 1:10 pm
actually, i'm really taking a liking to this style, you could really strap some power down on the hull with this setup:
http://www.ronniesairboats.com/mudboats.htm
http://www.airboat-transportation.com/muddhogg.html
i like the second one better with the cage over motor. if you could make it chort enough, you could put the driver seat on top, and i really like the rudder steering, set up like an airboat almost.
whats ya'lls thought? ecer seen one go through mud? they good?
-1436 flatbottom
Fri Nov 20, 2009 10:07 pm
Sat Nov 21, 2009 1:14 pm
