Mud Motor Questions
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=60879
Author:  bkram22 [ Sat Mar 21, 2015 5:24 pm ]
Post subject:  Mud Motor Questions
I currently own a 1654 tracker grizzly with a 40/30 Yamaha Jet on it. I have made many mods to the boat since I got it(new floor, custom fabricated gun box, lights, bigger fuel tank, extra battery etc.) Fully loaded with gear, men, and dog the boat is just too heavy for the motor with the jet on it and I am not crazy about the jet anyway.
So, I have two options a larger prop driven outboard, put the prop lower unit on my existing motor and it will be 40hp or get a mud motor.
I hunt a lot of different areas. 60% being mud flats and the other 40% semi-sandy bottom open water. I was curious if you guys had any advice if I were to slap a mud motor on my rig. I am not very educated on them and living on the Eastern Shore of Maryland they aren't the most popular motors to be running. Any advice would be greatly appreciated.
Author:  brycecheramie [ Sun Mar 22, 2015 6:44 pm ]
Post subject:  Re: Mud Motor Questions
Im not sure how a jet drive compares to an outboard with a prop, but if you are not happy with the performance of a 40hp outboard with the load you run, a Mudmotor will just make you more upset.
They dont compare to an outboard stock to stock.
If you rather a mudmotor, i would say you would have to mod it right away for you to be happy.
Author:  bkram22 [ Sun Mar 22, 2015 8:15 pm ]
I have a 40/30 Jet. It's a 40 hp motor; but only puts out roughly 30 hp due to the jet lower unit. I was looking at the 44 hp Sport V by Mud Buddy. You don't think this will be comparable or better than what I have now?
Author:  brycecheramie [ Sun Mar 22, 2015 8:23 pm ]
Author:  brstanle [ Sun Mar 22, 2015 8:26 pm ]
Mud motor being what you need is debatable. What isn't debatable is that you should stay the hell away from the Sport V. They are a trouble-prone engine and mudbuddy's customer service is lacking to begin with.
A 40 or 50 hp outboard is going to walk all over a mud motor on your boat. If the jet isn't giving you any trouble, and the only problem is that it's slow, I wouldn't suggest going to a mud motor. I would go for a more powerful jet or a standard lower unit.
Author:  Quack N Stack [ Sun Mar 22, 2015 9:01 pm ]
Author:  bkram22 [ Sun Mar 22, 2015 9:19 pm ]
What exactly do pods do for the boat? I'm curious because I own a sheet metal shop and could fab the pods up myself. I just was never sure what exactly they do.
Author:  brstanle [ Sun Mar 22, 2015 9:25 pm ]
They provide buoyancy behind the motor, which lifts the ass end up and helps with the running attitude of the boat. Offsets a lot of the effect of having a heavy motor cantilevered off the back of the boat.
Author:  bkram22 [ Sun Mar 22, 2015 9:27 pm ]
Would it help with getting my boat up on plane? The jet I have really struggles with getting the boat up on plane
Author:  brstanle [ Sun Mar 22, 2015 9:33 pm ]
Yes. It would also get you on plane in shallower water.
Author:  Quack N Stack [ Sun Mar 22, 2015 9:47 pm ]
Sounds to me like you should put pods on it, prop LU back on and maybe a jack plate and you would be set.
Author:  bkram22 [ Sun Mar 22, 2015 9:58 pm ]
Sounds like I may go that route. Are there any threads on here that give ideas on dimensions for pods?
Author:  brycecheramie [ Sun Mar 22, 2015 10:02 pm ]
Author:  Quack N Stack [ Sun Mar 22, 2015 10:17 pm ]
Author:  GDSArgo [ Mon Mar 23, 2015 4:49 pm ]
Author:  bkram22 [ Mon Mar 23, 2015 11:15 pm ]
I live in Bethel, Delaware
Author:  GDSArgo [ Tue Mar 24, 2015 3:47 am ]
So I'm guessing you pretty much hunt the naticoke river if so that's a lot of tide you're fighting when it gets running opposite direction you want to go. Add pods and a prop you'll see a big difference in performance.
