Gator glide question, how about ya frog?? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=60897 |
Author: | Quackkillz [ Sun Mar 22, 2015 5:14 pm ] |
Post subject: | Gator glide question, how about ya frog?? |
It's getting closer for my boat to be finished and I'm thinking about all the little things I'm gonna have to do to get it ready. One question I have that may sound dumb to some is should I paint the boat first and do the gator glide last or do the gator glide first and paint it last. Which way is easier? Or is it just personal preference? I'm guessing if I tape it off good it doesn't matter which one I do first. I'm hoping this doesn't come off as bow rope storage thread, lol. Sent from my SAMSUNG-SM-N900A using Tapatalk |
Author: | Quack N Stack [ Sun Mar 22, 2015 5:19 pm ] |
Post subject: | Re: Gator glide question, how about ya frog?? |
I would do it while its not painted at all then just tape it off when you paint the boat. That way you got a good clean surface |
Author: | stu [ Sun Mar 22, 2015 5:55 pm ] |
When I got my boat (bare metal),I put the GG on first. Problem was when I went to tape off the GG to paint the boat, the tape wouldn't stick to the GG. I'm painting first next time. Sent from my iPad using Tapatalk HD |
Author: | jc [ Sun Mar 22, 2015 5:59 pm ] |
Yes I would Gator Glide first to the bare aluminum and then paint. Tape it off like quack n stack said and paint the rest of the boat. Good part is if you get any paint on the gator glide I don't think it will stick. That stuff is slick as hell. |
Author: | SETx Longtail [ Sun Mar 22, 2015 6:05 pm ] |
My hull was built and painted and just left the bottom unpainted. I'll tape off the sides a couple inches up and scuff the paint and do my GG. -6 of one, half dozen of the other..... |
Author: | stu [ Sun Mar 22, 2015 6:55 pm ] |
^^^ this is the way I should have done it. Sent from my iPad using Tapatalk HD |
Author: | Quackkillz [ Sun Mar 22, 2015 7:12 pm ] |
Thanks, I'll probably paint the hull first Sent from my SAMSUNG-SM-N900A using Tapatalk |
Author: | LB200 [ Mon Mar 23, 2015 4:58 am ] |
Where is Frog? I am sure he can tell you exactly how to do it to save yourself any headaches |
Author: | Frog [ Mon Mar 23, 2015 9:50 am ] |
Author: | LB200 [ Mon Mar 23, 2015 10:31 am ] |
Stupid question but I am curious. Could you paint after the GG and use steel wool to scrub the overspray off the GG? |
Author: | brstanle [ Mon Mar 23, 2015 11:17 am ] |
You'd probably remove the GG too. |
Author: | Frog [ Mon Mar 23, 2015 11:32 am ] |
As long as the GG is cured well you could wipe of the overspray with acetone very easy if you did it right away. The steel wool will scuff it. Again the GG should be cured before trying any of this. Scotch bite pad would be a better choice over steel wool but will still scuff it a little. I try to mask or use a shield. |
Author: | DeltaRunner [ Mon Mar 23, 2015 2:36 pm ] |
Paint first then gg. |
Author: | DeltaRunner [ Mon Mar 23, 2015 2:40 pm ] |
Author: | stu [ Mon Mar 23, 2015 2:53 pm ] |
I used acetone to take the overspray off the GG. Not a big deal. Sent from my iPhone using Tapatalk |
Author: | SETx Longtail [ Mon Mar 23, 2015 4:47 pm ] |
That paint looks good Delta. What stencils?? |
Author: | DeltaRunner [ Mon Mar 23, 2015 4:52 pm ] |
Author: | DmaxHunter [ Mon Mar 23, 2015 5:31 pm ] |
Kind of looks like a bottom land, nice job. Better strap her down now... |
Author: | Quackkillz [ Mon Mar 23, 2015 6:17 pm ] |
That is a nice paint job, I'm just going with aluminum boat green from duralux, then I have the slate gator base and the graphite g2. Sent from my SAMSUNG-SM-N900A using Tapatalk |
Author: | Frog [ Mon Mar 23, 2015 8:41 pm ] |
Author: | Mudhole [ Tue Mar 24, 2015 12:48 pm ] |
I want to go over my steel flex with GG this summer, how are yall lifting your boats off the trailers? I don't wanna go thru the whole ordeal of flipping it over!! |
Author: | WhoDat88 [ Tue Mar 24, 2015 12:50 pm ] |
After reading this thread I am glad I decided to have KP add it to my new rig before I recieve it. It is worth the money to have him do it professionally for me. |
Author: | Quackkillz [ Tue Mar 24, 2015 3:39 pm ] |
Author: | Quackkillz [ Tue Mar 24, 2015 3:42 pm ] |
