It is currently Sat Jun 28, 2025 12:35 am
Reply to topic  [ 31 posts ]
 Older MB Hyper Drive Questions.
Post Older MB Hyper Drive Questions.
Guys I'm new to owning a surface drive. I've had Longtails but this is a new beast to me. I bought a 2005 29 vanguard Mud Buddy Hyper Drive from a fella. It's on my 1652 Seaark. It runs really good. No tach yet so I can't give you rpms. The prop is factory he said. It measures 10 inches across. Took it out this morning and got 10 mph tops.
My 1st question is how can I be sure this motor is for a tall transom? He said it was but that's me taking his word. Next question is what can give me more speed? I know moving some weight up front will help but any other suggestions?
Sat Apr 04, 2015 10:07 am
Post Re: Older MB Hyper Drive Questions.
Prop is worn out. It should be around 12"
Sat Apr 04, 2015 10:46 am
I figured on buying a big blade this week. Hopefully that helps
Sat Apr 04, 2015 1:39 pm
How many bolts are in the top cover of the belt housing
Sat Apr 04, 2015 5:41 pm
Sat Apr 04, 2015 6:22 pm
Sat Apr 04, 2015 7:41 pm
Then I hate to break it to ya but I believe that is a short transom motor
Sat Apr 04, 2015 8:09 pm
Yes four bolts is short, six is tall
Sat Apr 04, 2015 9:08 pm
Sat Apr 04, 2015 9:38 pm
^^^Agreed. The older motors don't have the same bolt hole numbers as the new ones.
Sat Apr 04, 2015 10:10 pm
Sun Apr 05, 2015 12:55 am
Here's a side view
Sun Apr 05, 2015 1:28 am
That looks like a short transom motor on a tall transom boat.
2014 Pro Drive Gen 3
2014 17x54 X-Series
Sun Apr 05, 2015 2:03 am
I can't tell.. I'm going to call mb tomorrow. When the motor is trimmed down the shaft/prop is pretty far in the water. It looks like to me the shaft is longer that the near surface drives. But honestly I don't know. It's trimmed all the way up in the pic here
Sun Apr 05, 2015 5:47 am
Sun Apr 05, 2015 6:05 am
1854 Prodigy DPE Level 3 HDR
Sun Apr 05, 2015 6:14 am
I was lied to then. Guess I need to look into getting the transom cut down or getting a new boat or motor.
I guess this explains a lot of the performance issues too.
Thanks for your help guys
Sun Apr 05, 2015 6:37 am
Shouldn't be too hard to find somebody to cut the transom.
Sun Apr 05, 2015 6:56 am
Short transom frame someone has installed a 48" long transom out drive to. We built one similar using a 18Hp 2005 MB small block frame, which we modified to a 35 hp BB Van. MB 18 short transom frame came with a 32" outdrive and a threaded prop. We put the 48" long transome outdrive on it to get the prop back in cleaner less aerated water for better bite. Had to change the top belt pully from a 32T to a 36T. It ran great with a BB prop. Does it have the Thompson or Bear electric trim actuator, or the Air cylinder type trim? With the 48" drive on the short transom frame you may have to shime transom to get the right trim angle, to get motor to level out more, so prop doesn't run as deep. You probably need a new prop and should be able to turn a 11x10 BB. Top pulley should be a 34T bottom a 50T.
Sun Apr 05, 2015 7:03 am
That sounds complicated. So this is a short transom frame with a tall transom outdrive?
Sun Apr 05, 2015 7:21 am
From what I can see in pictures it looks like a moded short transom. It'll work OK if transom is cut down and shim put behind clamp.
Sun Apr 05, 2015 7:28 am
Sun Apr 05, 2015 8:13 am
2014 17x54 X-Series
Sun Apr 05, 2015 8:26 am
If you wana sell it .....
Sun Apr 05, 2015 11:44 am
That looks like the Louisiana special that Mudbuddy made early on. Had a long tail with a short transom.
Sun Apr 05, 2015 1:27 pm
Sun Apr 05, 2015 2:56 pm
The 29 should turn the big blade fine. I have a modded 27 that's probably right around 29hp. Turns the BB 4200. I get the same speeds out of the stock 11x10 prop but better mud performance with the bb
Sun Apr 05, 2015 7:36 pm
That is the original hyperdrive frame and was made from late 03-early 05. That motor only came with 1 size belt box and a short transom model had a 36" drive and a tall transom model came with 48" drive...........that is a 48" drive.
Sun Apr 05, 2015 8:10 pm
Sun Apr 05, 2015 8:28 pm
Yes
Sun Apr 05, 2015 8:57 pm
Sun Apr 05, 2015 9:05 pm
Users browsing this forum: No registered users and 275 guests
