It is currently Fri Jun 27, 2025 5:45 pm
Reply to topic  [ 15 posts ]
 question?
Post question?
Having a problem,does anybody kno why my gas bulb is clasping when I am running??I can only run about 75 yards than it happens.its a 2013 GTR
Fri May 15, 2015 7:18 pm
Post Re: question?
You don't have a vent on your fuel tank. Loosen the gas cap. The new caps don't vent well
Fri May 15, 2015 7:21 pm
Post Re: question?
Refurbishing a Prodrive
Fri May 15, 2015 7:22 pm
Post Re: question?
It's a custom aluminum gas tank,used it two weeks ago and didn't do it.started this past weekend half way threw the fishing trip
Fri May 15, 2015 7:27 pm
Post Re: question?
Fri May 15, 2015 7:33 pm
Post Re: question?
Clogged vent line? Kinked vent line? Kinked fuel line?
17' CAT 5 with 37 GTR
Fri May 15, 2015 8:02 pm
Post Re: question?
What type of fuel line do you have?
Is it the grey colored fuel line?
Fri May 15, 2015 8:25 pm
Post Re: question?
It's the blue one and the hose has no kinks any were
Fri May 15, 2015 8:27 pm
Post Re: question?
Fri May 15, 2015 8:32 pm
Post Re: question?
Make sure your tank is vented either through the cap or through an overflow line.
That blue hose is junk. It has a plastic liner on the inside that the ethanol will cause to lose its adhesion to the hose inner wall.
You can check this by getting a short piece of the black hose and drop it in a portable tank. See if your bulb collapses. If it doesn't collapse, you have solved the problem. Replace that junk.
Fri May 15, 2015 8:41 pm
Post Re: question?
I'll try this tomorrow,and I'll let yall kno if it works
Fri May 15, 2015 9:06 pm
Post Re: question?
Used a diffrent hose and a tank and it ran perfect.used the same primer bulb
Sat May 16, 2015 10:47 am
Post Re: question?
Cut that blue hose open and look at what you see. That plastic liner will be separated and collapsed.
Sat May 16, 2015 1:47 pm
Post Re: question?
Blue, have you ever seen it break apart like this?
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sat May 16, 2015 3:41 pm
Post Re: question?
Now I have! LOL
I have the gray in my hull from when it was built. I replaced the blue in the boat at the camp with the black. Looks like I will be re-routing fuel line beneath another floor, soon! How long was that one in service? Looks like it just got brittle. Certainly can see the gasoline enamel staining.
Sun May 17, 2015 8:54 am
Users browsing this forum: No registered users and 227 guests
