question?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=61807
Author:  drake101 [ Fri May 15, 2015 7:18 pm ]
Post subject:  question?
Having a problem,does anybody kno why my gas bulb is clasping when I am running??I can only run about 75 yards than it happens.its a 2013 GTR
Author:  scarygary [ Fri May 15, 2015 7:21 pm ]
Post subject:  Re: question?
You don't have a vent on your fuel tank. Loosen the gas cap. The new caps don't vent well
Author:  brycecheramie [ Fri May 15, 2015 7:22 pm ]
Author:  drake101 [ Fri May 15, 2015 7:27 pm ]
It's a custom aluminum gas tank,used it two weeks ago and didn't do it.started this past weekend half way threw the fishing trip
Author:  brycecheramie [ Fri May 15, 2015 7:33 pm ]
Author:  Over the LINE [ Fri May 15, 2015 8:02 pm ]
Clogged vent line? Kinked vent line? Kinked fuel line?
Author:  brycecheramie [ Fri May 15, 2015 8:25 pm ]
What type of fuel line do you have?
Is it the grey colored fuel line?
Author:  drake101 [ Fri May 15, 2015 8:27 pm ]
It's the blue one and the hose has no kinks any were
Author:  brycecheramie [ Fri May 15, 2015 8:32 pm ]
Author:  BlueShamu [ Fri May 15, 2015 8:41 pm ]
Make sure your tank is vented either through the cap or through an overflow line.
That blue hose is junk. It has a plastic liner on the inside that the ethanol will cause to lose its adhesion to the hose inner wall.
You can check this by getting a short piece of the black hose and drop it in a portable tank. See if your bulb collapses. If it doesn't collapse, you have solved the problem. Replace that junk.
Most liberals seem to suffer from the same mental condition....it's called stupidity!
Author:  drake101 [ Fri May 15, 2015 9:06 pm ]
I'll try this tomorrow,and I'll let yall kno if it works
Author:  drake101 [ Sat May 16, 2015 10:47 am ]
Used a diffrent hose and a tank and it ran perfect.used the same primer bulb
Author:  BlueShamu [ Sat May 16, 2015 1:47 pm ]
Cut that blue hose open and look at what you see. That plastic liner will be separated and collapsed.
Author:  kibb [ Sat May 16, 2015 3:41 pm ]
Blue, have you ever seen it break apart like this?
Author:  BlueShamu [ Sun May 17, 2015 8:54 am ]
Now I have! LOL
I have the gray in my hull from when it was built. I replaced the blue in the boat at the camp with the black. Looks like I will be re-routing fuel line beneath another floor, soon! How long was that one in service? Looks like it just got brittle. Certainly can see the gasoline enamel staining.
