poodriveowner
 slack in steering on pro drive
I have a 2007 36 pro drive and I can hold the lower unit stationary and grab the tiller handle and move the whole motor but the lower unit stay on place. Any ideas?
Sat Jul 04, 2015 11:20 pm |
jammm112
 Re: slack in steering on pro drive
I have some small movement from the hole power and lower end wiggling in the main housing. I have an 09 ..
Wed Jul 08, 2015 9:44 pm |
Russ
Be careful. You may be the proud owner of a full power sideways unit.
Wed Jul 08, 2015 9:50 pm |
BlueShamu
There is wiggle room. How much movement you talking about?
Wed Jul 08, 2015 10:03 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
Yall need tower bushings. Cheap and easy
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Thu Jul 09, 2015 3:28 am |
Will
Man some folks are quick to judge... It could be a number of things but it looks like he's saying side to side not the "worn out bushing wobble" where it looks like a bobble head back there when on step.
If it is a manual reverse (which I assume due to the year), the pin or the hole in the reverse plate the locking pin goes in may have wear on it.
If it has the hydro reverse, the reverse gear is what holds it and the teeth can get wear on them which will create some slack and cause side to side movement. You can adjust it and get some play out of it by jumping a tooth.
These are the two things that come into play for side to side slack, either way, put it in reverse and see if you still have play...
The up and down all around wobble is either a dry tower that needs grease or worn out bushings and in many cases the bushing will be fine but the aluminum on the lower units shaft that the bushing ride on will have wear on it. In either case, you can pump it tight with grease to buy some time or change out the bushings but if the aluminum is worn, that gets pricey.
However, a little play is expected, the tolerances are large so it really depends on how much movement you're talking about here.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Thu Jul 09, 2015 4:33 am |
fredbear012
Thu Jul 09, 2015 5:55 am |
Bug
Joined: Sat Oct 29, 2011 10:28 am Posts: 1068 Location: Tallahassee, Fl
Mine looks like its almost barely attached when running a bad chop! Let ProDrive check it out if it really concerns you. Slack is normal, play (bout 1") between powerhead and lower is normal. Bushings get a little wear and it looks worse than it is. If there's a wink of play in the pins it translates into a lot more when comparing it between tiller and prop... Video?
_________________ PRODRIVE 1860 CC "Let the good times roll" Luck??? The bassards don't stand a chance!
Fri Jul 10, 2015 4:48 pm |
BlueShamu
Just scroll to around the 2:50 mark on this video to see slack in a nice chop. It's a short part of the video. But, the slack is pretty obvious. http://youtu.be/FGGybe5OhZMMost liberals seem to suffer from the same mental condition....it's called stupidity!
Fri Jul 10, 2015 5:11 pm |
Bug
Blue, whats the title of that vid? I can't get to it through the link and wanna compare mine to it...
Fri Jul 10, 2015 5:59 pm |
Bug
Nevermind that, it worked on the phone. Yup, that's a familiar sight...
Fri Jul 10, 2015 6:03 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
Fucking Junk
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
Fri Jul 10, 2015 6:29 pm |
JIMMY W
Just joking
Fri Jul 10, 2015 6:30 pm |
Bug
J.W.
Fri Jul 10, 2015 6:38 pm |
JIMMY W
Sat Jul 11, 2015 11:28 am |
