It is currently Thu Jun 26, 2025 11:14 am
[ 5 posts ] |
Can I get a jack plate mounted on this transom?
bueller
Looking to mount a T-H Marine Hi-jacker on my boat so I can run a long shaft outboard motor for bowfishing. Does it look like I have enough of a surface to safely mount a jack plate to? I see there are 2 mounting holes and they look pretty far apart so I'd hate to rip the jack plate off because the transom is only 4 or 5" tall.
_________________ 1754 Beavertail - 35hp SD
Tue Aug 25, 2015 5:13 pm |
jc
 Re: Can I get a jack plate mounted on this transom?
It will mount on the outside of the transom. You will be fine.
Tue Aug 25, 2015 6:08 pm |
BlueShamu
JC, does your transom have vertical supports of any sort on the inside that the jack plate bolting is mounted against?
I wouldn't be a fan of mounting it to the transom with just the horizontal support and a couple of knee braces spaced to the sides. The lower bolting hardware would have to mount to the thin aluminum transom.
Wed Aug 26, 2015 5:50 am |
bueller
Wed Aug 26, 2015 11:40 am |
jc
Thats just a picture I googled up, not my boat. Won't the jack plate have a bigger flat surface against the transom than the actual motor has? The aluminum angle is probably 3 or 4 inches wide on each side and a motor bracket might be 2 inches wide. I would think if your transom will hold the motor now it would be fine with the jack plate. Or am I missing something?
Wed Aug 26, 2015 6:00 pm |
[ 5 posts ] |
Users browsing this forum: Google [Bot] and 188 guests |
