HELP MERCURY TRIM http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=63439 |
Author: | CZECHHOME [ Sat Aug 29, 2015 11:46 am ] |
Post subject: | HELP MERCURY TRIM |
It on a 2015 HD MUD BUDDY only has 8 hours on it . Worked good and then nothing . When u push the trim button you can hear a clicking from around the stater . I know it could be the switch or the fuse . Is there anything else I can check. |
Author: | CZECHHOME [ Sun Aug 30, 2015 6:57 am ] |
Post subject: | Re: HELP MERCURY TRIM |
ANYONE? |
Author: | DmaxHunter [ Sun Aug 30, 2015 10:00 am ] |
There are two trim relays located on the #1 cylinder side ( oil fill ) attached to frame. There are also two circuit breakers under wire cover. Are you able to trim up or down? Or is this happening during both directions? |
Author: | CZECHHOME [ Sun Aug 30, 2015 11:11 am ] |
Will not do nothing up down . There two breaker does both go with the trim ? There two relay if one goes bad will it still work one way |
Author: | DmaxHunter [ Sun Aug 30, 2015 2:15 pm ] |
The relays are independent from each other, one for up one for down. They shouldn't both go bad unless something else is wrong like wiring, trim motor. You can try and use a jumper wire and bypass circuit breaker, or take leads directly from trim motor and hook to battery. Swapping polarity will change motor direction. Do you have a dealer close, or mechanically inclined. |
Author: | CZECHHOME [ Sun Aug 30, 2015 2:28 pm ] |
Not A mud motor dealer around . I am some what mechanically inclined. Just like to ask ??? before tear it apart .. Goose season open Tuesday and boat is at the beach will be heading that way tomorrow just wanted a idea where to start . If i look st the wiring diagram from mud buddy it shows the relay on the top of the trim motor but cant remember if i saw it there . |
Author: | DmaxHunter [ Sun Aug 30, 2015 3:44 pm ] |
Pm sent |
Author: | CZECHHOME [ Tue Sep 01, 2015 5:53 pm ] |
UPDATE .. AFTER CHECKING BREAKER ,SWITCH, RELAY , WIRES , I TAP THE TRIM MOTOR AND IT WORK WOULD GO DOWN GREAT ,UP SLOW AND SOUNDED FUNNY AND WOULD STOP TAP IT AGAIN AND WOULD WORK AGAIN . SO I AM GUESSING MOTOR IS GOING OUT I ALSO RAN WIRES FROM THE BATTERIES TO THE TRIM AND DONE THE SAME .. WHAT THE BEST WAY TO CHECK THE OIL IN THE TRIM MOTOR ?? |
Author: | DmaxHunter [ Wed Sep 02, 2015 5:24 am ] |
Dennyedwards had a thread on how he refilled his, it's best to remove and fill in a work bench |
