Best way to pull an empty trailer http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=63494 |
Author: | kcudslayer [ Tue Sep 01, 2015 8:46 pm ] |
Post subject: | Best way to pull an empty trailer |
I am making the trek to texas next weekend from illinois. Jay will have my boat done and I will be picking the motor up at Gatortail on the way. My trailer I purchased used and fabbed it up for my boat and refinished it. I will be pulling it down empty and it likes to bounce a lot any ideas on adding weight to lessen the bounce. thought about sand bags but no goo way to attach them |
Author: | Russ [ Tue Sep 01, 2015 8:52 pm ] |
Post subject: | Re: Best way to pull an empty trailer |
Take some plywood, clamp it on, then strap the sandbags or some concrete pads to it. You can use the concrete pads for something eventually. |
Author: | kcudslayer [ Tue Sep 01, 2015 10:12 pm ] |
Think a barrel full of water wedged between the bunks would work? |
Author: | netman [ Tue Sep 01, 2015 10:36 pm ] |
Barrel full of coal strapped on it. Leave the barrel and the coal there for someone to heat their home with. Everybody but Obama loves coal. |
Author: | flint87 [ Wed Sep 02, 2015 3:02 am ] |
I hauled my trailer empty from Atlanta to New Orleans. Used ratchet straps to secure some heavy scrap steel to the frame. Stopped the bounce and never came loose all the way. Sent from my iPhone using Tapatalk |
Author: | kcudslayer [ Wed Sep 02, 2015 3:03 am ] |
ill have to see how i can fasten some thing to it, shouldnt be too hard |
Author: | jakehawk9 [ Wed Sep 02, 2015 4:53 am ] |
Let it bounce. I hauled my trailer empty from wichita to Fort smith arkansas. It didn't come apart or leave the hitch Pretty sure most of MMT is humusexshuls in hiding |
Author: | cupped up [ Wed Sep 02, 2015 6:16 am ] |
I like to pull them with a truck. Being an empty trailer, you could probably do it with a car if you wanted. But it would be a pain to install a hitch unless you already have one. So use a truck. |
Author: | flint87 [ Wed Sep 02, 2015 9:33 am ] |
Author: | jakehawk9 [ Wed Sep 02, 2015 11:19 am ] |
Let me add that the trailer I went to get my boat with was a trailer for a 22' wake board boat. So it weighed like 1800lbs by itself, I just ratchet strapped my boat to the teailer. the trailer my boat is on currently, didn't come until after I got my boat home Pretty sure most of MMT is humusexshuls in hiding |
Author: | Russ [ Wed Sep 02, 2015 12:41 pm ] |
Great advice, jakehawk. |
Author: | JD145 [ Wed Sep 02, 2015 2:15 pm ] |
Author: | Terraboat [ Wed Sep 02, 2015 2:22 pm ] |
How about balancing the tires? I hade the same issue. A $20 balance job does wonders. I don't buy trailer tires now unless they throw in balancing. Adding weight works, but just hids real problem. Bearing and tires will last longer and run cooler also. |
Author: | flint87 [ Wed Sep 02, 2015 2:52 pm ] |
Author: | DUCK HEARSE [ Wed Sep 02, 2015 4:35 pm ] |
Just bought a new trailer with torsion axle not leaf springs in baton rouge and pulled it 200 miles double axle smooth ride ever when empty |
Author: | mizzippi jb [ Wed Sep 02, 2015 7:21 pm ] |
Geez it amazes me how people "overthink" things....when in all reality there's not much thinking involved in things like this at all. ![]() |
Author: | kcudslayer [ Wed Sep 02, 2015 7:41 pm ] |
Well the tires are balanced, i did them last week myself, it still bounces a little, just looking for advice, Got a barrel I'm going to fasten down and fill with water should work well |
Author: | Terraboat [ Wed Sep 02, 2015 8:59 pm ] |
Looking for advice? Have someone else balance your tires and take a little air out of your tires. They won't bounce. A well balanced tire will run smooth. Taking air out with no load will soften ride and not damage tire. Add more pressure when you put boat on. |
Author: | msm8281 [ Thu Sep 03, 2015 4:33 am ] |
Pick up every hitch hiker you can find and make them ride on it. |
