It is currently Thu Jun 26, 2025 3:11 pm
Reply to topic  [ 32 posts ]
 Depth finder / GPS ???
Post Depth finder / GPS ???
Any recommendations on a depth finder / GPS . I'm looking to mount one on my dash of my consol. I am not very familiar with what's out there.
Thu Aug 27, 2015 8:34 pm
Post Re: Depth finder / GPS ???
I vote garmin for user friendliness. It's all i've ever used with no complaints. The lowrance and hummiinbird are probably good also. I hear they take a little longer to get everything figured out.
Thu Aug 27, 2015 8:38 pm
I'm partial to lowrance. I like their option to add the sonic hub and control the radio via the head unit. Also the structure scan is pretty amazing as well. All the big name brands are good it simply what features you like having.
17*38 Klibert 23GDLT
Thu Aug 27, 2015 8:56 pm
I have a new humming bird 899ci mounted with a horizontal 2 pivot ram mount on my side console. It works good for what I need, anymore I think it's personal preference,
You can't fix stupid
"As long as the dog hits the water"
" Endorsed by Drake Waterfowl, Dakota Decoy, and Rig 'em Right Waterfowl"
"Stealthcraft Boats Pro Staff"
Thu Aug 27, 2015 9:08 pm
I'm a Garmin fan, but a friend of mine just bought a new Z7 and rigged it with Humminbird Helix7 machines and they seem to be pretty happening units!
PRODRIVE 1860 CC
"Let the good times roll"
Fri Aug 28, 2015 5:36 am
They will all get you to where you need to go. It depends on what you want to spend.
Fri Aug 28, 2015 6:04 am
Im going with lowrance 7 on my rig
Fri Aug 28, 2015 6:43 am
https://www.google.com/search?safe=acti ... 875&spud=0. That what your getting TPerkins ?
I'd like to get something I can mouth flush to my console. My budget is 1000$ or less. But I'm all for the best deal for the money !
Fri Aug 28, 2015 10:35 am
Yep that's it
Fri Aug 28, 2015 10:50 am
I might get that one. It's not flush but the mounting system looks pretty low profile.
Fri Aug 28, 2015 11:16 am
Fri Aug 28, 2015 11:21 am
Fri Aug 28, 2015 11:28 am
http://www.amazon.com/Lowrance-Elite-7- ... B00BNFG0PA
Flush mounting kit
1744 WC Custom
25 GTR
Fri Aug 28, 2015 12:30 pm
Lowrance makes a good product. But to use the structure scan you have to buy the 500 dollar transducer separate along with the regular transducer, so you have to run two of them. And with it being a flat transom down the back it's hard to mount them because the lower unit will interfere with side imaging in most places and you have dual motors with opposite spinning props so you've got even less room to work with because of the prop wash being thrown in both directions. Graphs now a days are amazing with detail but it doesn't take much to interfere with them because they are so sensitive. If you want simplicity get the HDS 7 touch as said, its touch screen and works almost like an iPhone. Humminbirds are a little more confusing and require you to really spend some time with it to learn how to use it but you can fine tune them a little more. Whatever you get go ahead and buy the navionics map card. It actually has most of the sabine basin marked really well. Also the problem with flush mounting is the screen is stuck at that angle so if the sun hits it just right you can't see the screen and you are sol because you can't angle it. Id honestly just mount it using the gimbal mount it comes with because you can adjust it for different sunlight conditions and the angle of the sun. I've had one flush mounted and I'll never do it again. If your back was to the sun you couldn't see anything on the screen without trying to throw a shadow over it with your hand.
Sorry for the long post but I just don't want to see you waste your money or not be as happy as you thought you were going to be because I see it all the time in the bass fishing world.
Fri Aug 28, 2015 12:55 pm
Honestly I care less about the structure scan. I know most of the areas I fish pretty damn well. I'm mainly concerned about a depth finder and GPS. Mainly GPS. I hardly ever run the Sabine River area or Sabine lake. I mainly stick to calcasieu ( Big ) lake area and west ward of Sabine lake. I just prefer I flush mount. Plus my consol is all ready set up for a flush mount. Plus One less thing to bump against and break. I appreciate your input though thank you.
Fri Aug 28, 2015 2:30 pm
BTW thanks for the mounting kit Calphil.
Fri Aug 28, 2015 9:12 pm
I have this setup on mine. Its a garmin echomap 43dv and its mounted in the T-rail towards the back but i have enough slack to slide it down the rail to the front for when im fishing
Sat Aug 29, 2015 7:13 am
Nope sorry that's not what I'm looking for . I'd just use my cell phone GPS if I wanted that set up. Thank you though.
Sat Aug 29, 2015 7:26 am
They have this, for people who cant afford a large unit and can't see worth shit
Sat Aug 29, 2015 2:54 pm
I can see fine. Like I said my budget is 1k$ . That should get me e decent size unit. Plus I want a GPS/ depth finder combo.
Sun Aug 30, 2015 1:20 am
The garmin echomaps are combos. The echomap 94 has a 9" screen. Its a grand
Sun Aug 30, 2015 7:13 am
They had a good sale on the Lowrance Elite 5 not long ago... I should have scooped one up then. Thats what I'll be going with next spring. Either that one, or a similar Garmin.
-Custom pool noodle
-stage 4 water wings
Sun Aug 30, 2015 9:43 am
http://www.southeasttexas.com/classifie ... distance=0
Sun Aug 30, 2015 11:02 am
I like the touch screen Garmin
Sun Aug 30, 2015 5:52 pm
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Sun Aug 30, 2015 6:02 pm
70 DV
Sun Aug 30, 2015 6:15 pm
The garmin 94 looks nice ! I'll prolly Waite till I get my boat so I can measure the right side of my console.
Sun Aug 30, 2015 7:46 pm
Huminbird 997si is all you need. I have used them all in a commercial fishing application and more than satisfied with the Huminbird units.
I got a shotgun,rifle and a Go Devil Surface Drive a country boy can survive.
35+hp GDSD engine mods by George Merta
18x48 GDSD boat
Fri Sep 04, 2015 12:11 am
Ok thanks ! I will take a look .
Fri Sep 04, 2015 8:43 am
Go with a Garmin
Fri Sep 04, 2015 11:54 am
Yep that's what I'm leaning towards !
Sat Sep 05, 2015 4:55 am
Ive been looking also lately being I have a new boat being built... I like Garmin in the past.. I believe im going to stay with them, but get one that will run the BlueChart and Vision cards.
GatorTail 18x54 extreme Center Console 37EFI "Ole Man Rig"
Sat Sep 05, 2015 9:07 am
Users browsing this forum: No registered users and 238 guests
