razorsgtr35
Joined: Sat Feb 09, 2013 10:02 pm Posts: 6 Location: Lewisville AR
 Go devil exhaust
Looking to put duals on a 09 35hp go devil? Anyone have any suggestions?
Thu Jan 21, 2016 10:24 pm |
brycecheramie
 Re: Go devil exhaust
You will have to fab up some brackets for the duals from mudbuddy to work with your motor. But its been done.
Thu Jan 21, 2016 11:29 pm |
DENNYEDWARDS
Won't need any brackets for these and you can build them yourself for about $25.
Fri Jan 22, 2016 9:31 am |
tyler_johnson
Joined: Mon Jan 21, 2013 6:22 pm Posts: 1094 Location: El Dorado-ish, AR
You keep pimping this idea, but I built a set of these and it didnt work, restricted flow so much from one cylinder it was barely pumping.
_________________ '13 GTR35 Stage 2 w/ EVT Exhaust, 1750 Voodoo Custom by DFOU!!
Fri Jan 22, 2016 9:49 am |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
Fri Jan 22, 2016 9:54 am |
tyler_johnson
lol it damn sure loves that EVT exhaust!! Boat may end up being for sale towards the end of the year!
Fri Jan 22, 2016 9:57 am |
DENNYEDWARDS
Fri Jan 22, 2016 10:17 am |
tyler_johnson
Leaky valves or low compression would not be found from a different muffler. It was like there was a potato stuck in the exhaust, swapped back over to my EVT and all is fine. Restriction of exhaust airflow was the problem, but I think I have an idea of a modification to make it work with the modifications that are in my motor.
Fri Jan 22, 2016 10:21 am |
riverrambler
Joined: Sun Feb 05, 2012 3:35 pm Posts: 162 Location: Muskogee, Ok
if the pic loads here is a pic of MB Duals I had on a go devil probably could have made it look a lil better. just an idea for you
Fri Jan 22, 2016 12:54 pm |
