bueller
 2060 too big for a 37efi?
Looking to upgrade boats this spring from a 1754 to something like an 1860 or 2060... is a 2060 Go Devil boat gonna be too big for a 37efi? I only use the boat for bowfishing shallow areas so top speed isn't a concern, mostly load carrying, but I would like to go a little faster than the 15mph I'm running with a full load in my boat right now (3 people and about 500lbs of generator, HPS lights, deck, troller, etc). Obviously an outboard is the logical choice but those aren't fun.
_________________ 1754 Beavertail - 35hp SD
Sat Jan 23, 2016 9:18 pm |
brycecheramie
 Re: 2060 too big for a 37efi?
Lots of people are getting good speeds out of an 18x60 with the 37EFI motors. I don't see why you wouldn't get good performance out of it.
Sat Jan 23, 2016 9:57 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
My setup does pretty well. Totes basically whatever I can fit in the hull. I have carried an older 250 Honda 4 wheeler, climbing stand, clothes for a couple days, cooler, rifle and shotgun cases, 2doz decoys and still stepped the load in deep water and got where I was going. It wasn't fast but carried it well.
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
Sat Jan 23, 2016 11:23 pm |
brickgw
I've been in a 2060 phowler with a GTR. It did fine stock and did even better after the heads and carb were done. The thing couId haul a pregnant elephant around. I wouldn't be worried a bit unless your trying to have some kinda speed boat.
Sun Jan 24, 2016 5:56 am |
woffman
Joined: Tue Jan 13, 2009 6:35 pm Posts: 208 Location: WI
I've got a 2060 Phowler and love it. I don't know as I would go any bigger but it hauls a load very well.
Sun Jan 24, 2016 8:49 am |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
I run an ancient 24 X 60 Monark with a 37 EFI. I average 20 mph with a 1000 lb load. The 20 X 60 GoDevil boat is hard to beat for carrying a load. If you have a need for speed get a smaller boat and go light.
_________________ so many rivers, so little time
Sun Jan 24, 2016 10:28 am |
Zeek569
Joined: Tue Oct 08, 2013 12:25 am Posts: 668 Location: Where the mud flats are
Are you running a 3 blade?
_________________ 18x48 extreme with 37 gtr past boats stage 2 37 gtr on 18x48 sportsman fab Gen 3 36 prodrive on 18x48 sportsman fab Gen 2 36 prodricr on cc 18x48 sportsman fab 07 gtr on 16x54 alweld
Sun Jan 24, 2016 10:54 am |
50fps
Sun Jan 24, 2016 12:07 pm |
woffman
Sun Jan 24, 2016 12:26 pm |
bueller
what props do you guys run on these big rigs? BB?
Sun Jan 24, 2016 3:48 pm |
woffman
Stock GT prop or a BB. The GT prop is a little faster in my experience.
Sun Jan 24, 2016 6:24 pm |
SETx Longtail
Factory GD 3 blade for me.
Sun Jan 24, 2016 10:15 pm |
Dherndon
Joined: Sat Mar 31, 2012 10:35 am Posts: 329 Location: Florida panhandle
_________________ 1650 custom sneak with 50efi HDR 1754 excel F86 44HDR Modded 23gtr with 1448 county line on the way
Mon Jan 25, 2016 8:48 am |
SETx Longtail
No, but I should have taken some  boat is "rated for" almost 1200lbs load and I figure I was close to 1000 that day. The little 250 is light in comparison to other 4 wheelers these days (it's an 86 model). I had a few sticks of firewood and a gas can stuck in there too. It was a load and didn't like to go against the current but it made it. My motor is bone stock, not modded in any way. To get it on plane in deep water headed into the river current I had to trim the motor up just enough to aereate the prop and gain some engine RPM but once the boat got on top of the water we were in business. Adjusted the trim for the load and headed out. I never checked speeds since I was busy watching what I was doing but it felt like around 20mph, turning around 3800 engine RPM. At no point did it ever feel sketchy or overloaded at all. Just needed to be careful about maneuvers and be mindful of the boat having short sides.
Mon Jan 25, 2016 9:11 am |
westwind
I'm thinking 2060 for my next boat which will be retirement present to me in 2 years.
I'm glad some others went that route and didn't regret it.
In my area a lot of guys run 60" bottom plate boats with outboards. Think big river setting not timber etc. The difference between the 18 and the 20 is the ride, the 20 is much better when it's rough.
Mon Jan 25, 2016 10:29 am |
