cranschau
 Aluminum Experts Help
How would .100 compare to .125? Both out of 5086. I know .125 will be heavier. But overall durability, weight, etc....any info would be appreciated.
Sat Jan 23, 2016 12:06 pm |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
 Re: Aluminum Experts Help
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
Sat Jan 23, 2016 12:23 pm |
cranschau
Comparing two different boats....would mainly be used in sloughs with cattails with some mud flats then also in a silt/sand river bottom. We don't have a ton of submerged logs or anything but I don't want something that can't take a little abuse either.
Sat Jan 23, 2016 1:13 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
What motor. Id get .125 just be safe. One you dent it it'll never be the same.
Sat Jan 23, 2016 1:25 pm |
cranschau
Sat Jan 23, 2016 1:37 pm |
msm8281
Big motor=thick boat!!!! Trust what everyone suggest!!
Sat Jan 23, 2016 2:00 pm |
cranschau
Sat Jan 23, 2016 2:09 pm |
duck_watcher12
Get the .125. I have .100 and it's not enough weight on the front end. Also make sure you get the bracing that goes the whole length of the boat. If you want speed and handling, havoc makes a great .100 boat. If you want a tank there's several that make a .125 boat that's tough and will handle abuse.
Sat Jan 23, 2016 2:59 pm |
cranschau
Sat Jan 23, 2016 3:06 pm |
duck_watcher12
Yes they do and if you ask I'm sure you can have them add a couple extra for more strength on the bottom. But if you are gonna be running stumps I'd say go heavier like .125 or .190. Also definitely don't go less than 17ft with a 35 it's better to go 18 if you can afford to. I went 1648 and mine isn't right
Sat Jan 23, 2016 5:29 pm |
cranschau
Sat Jan 23, 2016 5:54 pm |
duck_watcher12
17 gives you the length and extra weight up front to help keep the back end from sitting too low in the water and the wider you go the better 48 is barely wide enough to float the monster you'll be putting on the boat
Sat Jan 23, 2016 6:46 pm |
banded-mallard
If you get a thin hull, the Sandy bottoms will "sand" the bottom of your hull thus making it paper thin. Go .125
Sat Jan 23, 2016 6:53 pm |
DENNYEDWARDS
Joined: Sun Aug 09, 2009 12:50 pm Posts: 574 Location: Muscatine, Iowa
Cheap an lite consider one of these.
Sun Jan 24, 2016 7:28 am |
Mudhole
Joined: Wed Jan 14, 2009 7:05 am Posts: 716 Location: NW La.
.100 is what regular john boats are made with! There's a reason mud motor hills are .125!!!
_________________ "Gofer Everette?"
Sun Jan 24, 2016 7:56 am |
jakehawk9
Joined: Wed Jul 01, 2015 6:06 pm Posts: 1447 Location: South central, ks
Sun Jan 24, 2016 7:59 am |
DENNYEDWARDS
Sun Jan 24, 2016 8:19 am |
brickgw
Sun Jan 24, 2016 9:12 am |
Ricerunner
Joined: Fri Sep 11, 2015 6:56 pm Posts: 887 Location: Summerville, SC
Sun Jan 24, 2016 9:14 am |
Ricerunner
Also if havoc is your preference you can get it in .125
Sun Jan 24, 2016 9:52 am |
UNCLE-J
Joined: Fri Jul 24, 2009 7:26 am Posts: 10388 Location: S-Ville, LA
Interesting facts
Mon Jan 25, 2016 2:52 pm |
jakehawk9
Mon Jan 25, 2016 3:38 pm |
