| bow lights http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=6558 |
| Author: | Drake-cutter [ Mon Dec 14, 2009 8:52 pm ] |
| Post subject: | bow lights |
I got me a new boat and am trying to come up with a good set-up for the bow lights. The boat has a pointed front, wondering what everyone has come up with. Post some pics for me to get some ideas! Thanks |
| Author: | take'emgator [ Mon Dec 14, 2009 9:29 pm ] |
| Post subject: | Re: bow lights |
| Author: | JpEater [ Tue Dec 15, 2009 8:43 am ] |
I am looking for some too. I am having a hard time finding the lights with the black bezel. I have found plenty of chrome but not black. |
| Author: | richardb [ Tue Dec 15, 2009 9:52 am ] |
Here’s my set up Prodrive light package with the running light below bought the black running light at a local boat shop they had to order it but were able to get it. 100_3094.JPG |
| Author: | Capt Jeff Kraynik [ Tue Dec 15, 2009 10:45 am ] |
Are you talking fogg lights or nav lights? Here's the new Livorsi Marine nav's we put on all of our boats. Livorsi has developed a navigation light compact in size, with powerful lighting and a sleek contemporary look. Now made of 316 stainless steel! As you know, LED lights outlast and out shine regular incandescent bulbs. LED lights use up to 90% less energy; these Livorsi nav lights only consume 1/10th of an amp at 14 volts. This means a longer life and less rigging time switching out lights. These lights are to be used on any vessel up to 65 feet and have a visibility of 2 nautical miles! These lights are designed to be mounted on a vertical surface, to allow the light pattern to be unobstructed from view. Measures 3 1/4"W x 1 3/4" H x 7/8" D NMMA accepted ABYC & USCG certified Available for Port or Starboard Made of 316 stainless steel port LEDNLRSS $69 starboard LEDNLGSS $69 |
| Author: | Drake-cutter [ Tue Dec 15, 2009 2:56 pm ] |
Sorry for the confusion, I am talking about spot lights for the bow and how they are mounted. |
| Author: | Drake-cutter [ Wed Dec 23, 2009 8:40 pm ] |
Seriously...........I know folks runs spot lights on the front of your boat.........just a little help please! |
| Author: | Team Camo [ Wed Dec 23, 2009 8:50 pm ] |
Too many different styles of lights, each mounting differently. I bought a set of docking lights from Academy and just bolted em thru the deck. I used to have some big arse offroad lights that were bright as hell, but too big and bulky. They mounted the same way. Pick your light first, then figure out how to make it work. |
| Author: | WestEndAngler [ Wed Dec 23, 2009 9:41 pm ] |
I don't run with these on... I use a head light lamp. |
| Author: | dead animal [ Wed Dec 23, 2009 10:59 pm ] |
nice lights capt jeff!!! i'm gonna put a set of those on my next boat. |
| Author: | Capt. Jon [ Thu Dec 24, 2009 12:44 am ] |
Here's some bow lights. But I don't think that you will be able to get them in time... |
| Author: | jpc014 [ Thu Dec 24, 2009 8:47 am ] |
HARD HAT LIGHT!!!! wear it and be done with it! |
| Author: | DMC [ Thu Dec 24, 2009 9:08 am ] |
| Author: | WestEndAngler [ Thu Dec 24, 2009 10:43 am ] |
| Author: | BradS [ Thu Dec 24, 2009 3:28 pm ] |
Im going to order 2 of these and put them in a box for protection http://www.sidebysidesports.com/kr7hidoflics.html |
| Author: | JIMMY W [ Thu Dec 24, 2009 4:48 pm ] |
This is the shit http://www.ok4wd.com/index.php/catalog/ ... oad_light/ |
| Author: | BradS [ Thu Dec 24, 2009 7:35 pm ] |
| Author: | idabilly [ Fri Dec 25, 2009 10:27 am ] |
If you buy 55 watt lights to make up your bow lights you will soon be chucking the bulbs and replacing them with 100 watters. I have the Mudbuddy twin 130 light kit and I have found it to be a good amount of light for my purposes. |
| Author: | stanco [ Fri Dec 25, 2009 12:01 pm ] |
| Author: | Quackiller08 [ Fri Dec 25, 2009 12:03 pm ] |
i think the next lights i put on my boat will be some hella 500s |
| Author: | Capt Jeff Kraynik [ Fri Dec 25, 2009 2:54 pm ] |
$75.00 dollars 1 million candle power aircraft landing light Replacement bulbs $17.00 @ Car Quest Moves from boat to boat 360 degrees w/o turning your boat |
| Author: | POKER1 [ Fri Dec 25, 2009 5:20 pm ] |
| Author: | Capt Jeff Kraynik [ Fri Dec 25, 2009 5:30 pm ] |
Only way to roll!!! Bow lights are a waste of money & weight. Sure, they look cool as another really cool option but have no real function except going forward. |
| Author: | Capt Jeff Kraynik [ Fri Dec 25, 2009 5:32 pm ] |
| Author: | WestEndAngler [ Fri Dec 25, 2009 7:55 pm ] |
They shouldn't even call them "bow lights" they should call them "DOCK LIGHTS" about all they're good as most have said and pointed out! |
| Author: | Quackiller08 [ Fri Dec 25, 2009 8:18 pm ] |
i use mine mainly in tight ditches and when puttin out decoys |
| Author: | JIMMY W [ Fri Dec 25, 2009 8:34 pm ] |
| Author: | deadbird8 [ Sat Dec 26, 2009 3:43 pm ] |
Replaced with 100Ws and added a relay for wiring to switch. I like being able to remove it or turn it around on a muddy road on the way out so the lenses dont get covered. Here is the wiring diagram and tips for wiring: http://www.allmudmotors.com/blogs/how-t ... th-diagram |
