push pole foot help! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=67154 |
Author: | Boattrash55 [ Fri Jun 10, 2016 4:27 pm ] |
Post subject: | push pole foot help! |
so I'm looking to make my own push pole out of a 1-1/4" or 1-1/2" wooden dowel I'm trying to find a push pole foot to put on the end of it.id like to find something i can just slide over the dowel and epoxy and screw in place. has anyone done this before or anybody have any recommendations or pics of what they have done? |
Author: | dead animal [ Fri Jun 10, 2016 4:30 pm ] |
Post subject: | Re: push pole foot help! |
google push pole foot. |
Author: | cb5331 [ Fri Jun 10, 2016 5:30 pm ] |
Hillside castings |
Author: | NannySlayer [ Fri Jun 10, 2016 5:33 pm ] |
How long are you going to make it? I bet the dowel is not gonna las long. Get a piece of aluminum pipe. Prolly end up lighters more durable than a wooden dowel |
Author: | Boattrash55 [ Fri Jun 10, 2016 5:58 pm ] |
I think I can get an 8-10 foot dowel. Just wanted something that would float |
Author: | NannySlayer [ Fri Jun 10, 2016 6:13 pm ] |
8 to 10 foot might be OK. Aluminum will float if you put a stopper in it. |
Author: | Boattrash55 [ Fri Jun 10, 2016 6:16 pm ] |
Would be a lot easier to get a foot that will slide in to a piece of conduit than one that slides over a dowel |
Author: | Frog [ Fri Jun 10, 2016 7:11 pm ] |
Find a straight cypress limb with a fork |
Author: | dead animal [ Fri Jun 10, 2016 8:36 pm ] |
i have a pushpole with a wooden dowel about 12' long. i found a duckbill foot that just slipped on the end and i drilled a hole through it and put a bolt in there. has worked for probly 10 years. |
Author: | WAD SHOOTER [ Fri Jun 10, 2016 11:16 pm ] |
Just make one out of pvc. Buy a T, 2 45s, and 2 caps. Make sure the 45s slide over the T, and the caps slide over the 45s. I've make several push pole feet out of pvc. Cheap and very effective. I found an old fiberglass pole that was a pole vault and made a foot for it out of pvc. Best push pole I've ever had. I've also made theme out of dowls like you are doing. If you dont want the pvc foot just buy a duck bill foot. Academy sells them for around $10 |
Author: | BERNIE255 [ Sat Jun 11, 2016 12:11 am ] |
Do you mind posting a pic of your pvc foot?^^ Sent from my iPhone using Tapatalk |
Author: | Boattrash55 [ Sat Jun 11, 2016 5:25 am ] |
Dead animal were did you find the foot you used? And I'll check out academy thanks guys! |
Author: | rubbinisracin [ Sun Jun 12, 2016 5:55 pm ] |
I got the hillside castings stuff, good stuff, but don't count on it floating. The forked limb sounds like a good cheap solution if your after cheap and a floater. |
Author: | Roostertail3 [ Mon Jun 13, 2016 7:22 pm ] |
I am thinking about buying the push pole foot as well as the spud handles and spikes. It says it fits in a schedule 40 aluminum pipe. Just courious if the aluminum gets hot to the touch during summer months? Also is aluminum electrical conduit schedule 40? Thanks for the info. |
Author: | rubbinisracin [ Mon Jun 13, 2016 7:27 pm ] |
It's for 1 inch schedule 40 aluminum pipe. So long as the id is 1 inch they will work. Mine haven't got hot yet but I haven't had them in the heat of the summer yet. |
Author: | dead animal [ Mon Jun 13, 2016 7:39 pm ] |
Author: | swamp_fox [ Mon Jun 13, 2016 7:50 pm ] |
I had one out of a wooden dowel that was about 10', my uncle made the foot out of aluminum and I don't have a pic. So I'm zero help...lol Fucking bee's drilled a hole in it and it snapped in half while I was leaning all 230 lbs on it. That was fun! Sent from my SAMSUNG-SM-G890A using Tapatalk |
Author: | Boattrash55 [ Tue Jun 14, 2016 5:08 am ] |
Thanks for all the help everyone I'll post what I come up with! |
Author: | ibfishinb [ Tue Jun 14, 2016 5:39 am ] |
Moonlighter or stiffy might have feet that will work. Sent from my SM-G920V using Tapatalk |
Author: | WAD SHOOTER [ Tue Jun 14, 2016 4:20 pm ] |
This is what I'm talking about with the pvc. This is a smaller version I made for my kayak. The pole I used is actually a small fiberglass cross bar used for high jump. The foot is cheap to make and very effective. |
Author: | Wood [ Fri Jun 17, 2016 11:42 am ] |
I used a 14 or 16' closet rod from stines/lowes/whatever, and a foot from academy. Sanded the end down a little to fit the foot snug, drilled a hole and ran a bolt through the foot. Works great till your buddy falls on it out in the gulf and snaps it in two. Down to about a 6' right now. Probably gonna redo it again this evening, 6' is just about useless. Total cost was about 30 bucks, 15 or so for the foot and 15 or so for the pole. Hoping to run across a pole vault one day to upgrade, but till then closet pole works pretty good. Sent from my SAMSUNG-SM-G890A using Tapatalk |
Author: | rob_E [ Fri Jun 17, 2016 12:46 pm ] |
Top rail for a chain link fence works with the academy foot and won't break. That's what I used. |
