It is currently Mon Jun 23, 2025 12:34 am
[ 6 posts ] |
Gatortail Switch Panel Problem
usfgeology
Joined: Thu Jan 26, 2012 6:37 pm Posts: 74 Location: Tampa, FL
Lately my electrical system was acting up but I only noticed it when it was dark out. Running in chop, my lightbar and nav lights would flicker on occasion. Other times they would be rock steady. Yet other times they would not be on at all unless I gave the panel a good whack.
So I smartened up and pulled the switch panel. Everything looked in order except one rogue black wire. This end of the wire looked twisted like it was in a twist-connector. But none of the connectors have black wires except the cigarette-plug outlet. I tried all my lights and nothing. But when I touched this black wire to the metal mounting plate for the switch panel, all my lights came on. It's a hot wire, no doubt, so it's not a grounding wire. But why would touching it to the boat metal, cause all the other switches to suddenly work?
Obviously this wire has been my culprit. Running in chop, it would bounce and probably was bouncing off bare metal causing the flicker. I'll try and post pictures so you can see.
One observation that may be useful is that the bilge switch worked all the time. Regardless of if that wire was touching the metal or not.
_________________ 1554 GTB w/ 25GTR
Thu Sep 15, 2016 2:45 pm |
Russ
 Re: Gatortail Switch Panel Problem
It's a hot wire, no doubt. What makes you think so? How many volts does it read on your multimeter?
Thu Sep 15, 2016 4:04 pm |
usfgeology
It sparked.
Thu Sep 15, 2016 4:31 pm |
rob_E
Joined: Wed Jan 25, 2012 12:03 pm Posts: 1763 Location: Prairieville, LA
Bet you 1 dollar it's a common / negative wire coming from the front of the boat and should be crimped in with the black wire going to your cigarette plug
_________________ 18X54 CC & 35 GTR w/ Hoyts Stage 1
Thu Sep 15, 2016 4:57 pm |
usfgeology
Fri Sep 16, 2016 7:35 am |
rob_E
Your welcome sir. Glad I could help.
Fri Sep 16, 2016 4:27 pm |
[ 6 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 395 guests |
