It is currently Mon Jun 23, 2025 6:39 am
Reply to topic  [ 13 posts ]
 After market starter
Post After market starter
My 35 mudbuddy is having issues turning over fast enough to start. Still have a couple troubleshooting issues to check, but wanted to know if anyone has used aftermarket starters.
I found a couple on Amazon for under $100 and the Briggs replacement is over $200. I want something reliable but don't want to waste money if aftermarket is comparable.
Any help is appreciated.
Thank you.
Thu Sep 08, 2016 10:43 am
Post Re: After market starter
There are 2 briggs replacements. One is around 80, the other is over 200. They both work. I'll dig up the one I ordered and post it in a bit.
Thu Sep 08, 2016 10:46 am
I apparently bought an aftermarket this last time. It's holding up fine and I'm cranking 215+ psi on the cylinders.
DB electrical snd0529 off amazon.
Thu Sep 08, 2016 10:52 am
Thu Sep 08, 2016 11:10 am
That was with both of the stock starters, cb. That I got from someone on here. That's a really nice guy. That "load tested" them. The one I linked above now has 25 hours without issue. More than 3 times what the other two had combined. [GRINNING FACE WITH SMILING EYES]
Thu Sep 08, 2016 11:27 am
I got the Amazon replacement in 2 Briggs Motors - both work fine even in sub-zero weather
Thu Sep 08, 2016 11:53 am
Thu Sep 08, 2016 11:56 am
Thanks guys.
Thu Sep 08, 2016 2:15 pm
I second DB Electrical. I've had one for almost 7 years now with zero problems.
Thu Sep 08, 2016 9:12 pm
I ordered one from DB Electrical.
Thanks again.
Fri Sep 09, 2016 7:33 am
I have been running DB electric trim pumps and resevoirs for about 4 years now with no issues. Its the older 3 wire mercury pumps but who cares.
Tue Sep 13, 2016 4:30 am
Swapped out the old starter with a new one from DB electrical and she turns over great now.
Thanks for the help guys.
Fri Sep 16, 2016 7:45 am
I just bought one too. Going to install tonight.
Kool-Aid Brigade
www.southernfowler.com
Fri Sep 16, 2016 10:23 am
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 408 guests
