GTR trim extension http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=68485 |
Author: | jd44 [ Sun Oct 02, 2016 1:22 pm ] |
Post subject: | GTR trim extension |
I have a 07 GTR with the old style trim. They used to have an aluminum extension that was installed on the ram of the trim unit that I believe GT used to make and install. I'm looking for one of those extensions. Would anyone have an older unit laying around that had this aluminum extension?? |
Author: | mizzippi jb [ Sun Oct 02, 2016 3:33 pm ] |
Post subject: | Re: GTR trim extension |
An extension or a cross member piece? I may have one in the shop if you're talking about the cross piece where the ram bolts to the frame up front Sent from my SM-G900V using Tapatalk |
Author: | jd44 [ Sun Oct 02, 2016 3:40 pm ] |
See the picture where there is the extension mounted? Not where it connects to frame. Rigged this up to make hunts this weekend but not right. |
Author: | mizzippi jb [ Sun Oct 02, 2016 4:06 pm ] |
Don't think mine had that, I'll check when I get home Sent from my SM-G900V using Tapatalk |
Author: | GatorDubea [ Sun Oct 02, 2016 4:23 pm ] |
mines a 07 and it didn't have it when I changed out my trim to the new style |
Author: | jd44 [ Sun Oct 02, 2016 4:45 pm ] |
Wish i had an old picture of it. But basically it was a sleeve that slipped on the shaft and had the same profile of the end of the original shaft. You had to put a bolt their the sleeve and the original shaft. I bought the motor in 2010 and it was on the oringial trim unit. |
Author: | mizzippi jb [ Sun Oct 02, 2016 4:47 pm ] |
That looks like an unnecessary hinge point that would make the trim do funny shit. Just my opinion Sent from my SM-G900V using Tapatalk |
Author: | jd44 [ Sun Oct 02, 2016 5:15 pm ] |
Yes, that's exactly what it does. Puts the whole system in a bind. But it got me thru a weekend of hunting. |
Author: | GatorDubea [ Tue Oct 04, 2016 11:58 am ] |
why not just bolt the shaft itself to that point instead of having the linkage ? I know you would loose some trim. |
Author: | jd44 [ Tue Oct 04, 2016 12:10 pm ] |
You can, but even with the pin in the highest hole you don't have enough trim to really run it in the right position. It will work that way, but you aren't getting the most out of the motor without being able to trim it high enough. |
