jd44
Joined: Tue Feb 02, 2010 9:33 pm Posts: 80 Location: Stephensville, Louisiana
 GTR trim extension
I have a 07 GTR with the old style trim. They used to have an aluminum extension that was installed on the ram of the trim unit that I believe GT used to make and install. I'm looking for one of those extensions. Would anyone have an older unit laying around that had this aluminum extension??
_________________ Boats and hoes! 2007 GatorTail 35 on 18' x 46" GatorTail hull
Sun Oct 02, 2016 1:22 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 Re: GTR trim extension
An extension or a cross member piece? I may have one in the shop if you're talking about the cross piece where the ram bolts to the frame up front
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Sun Oct 02, 2016 3:33 pm |
jd44
See the picture where there is the extension mounted? Not where it connects to frame. Rigged this up to make hunts this weekend but not right.
Sun Oct 02, 2016 3:40 pm |
mizzippi jb
Don't think mine had that, I'll check when I get home
Sun Oct 02, 2016 4:06 pm |
GatorDubea
Joined: Fri Jun 07, 2013 12:56 pm Posts: 491 Location: Alexandria, La
mines a 07 and it didn't have it when I changed out my trim to the new style
_________________ 07 16x50 w/ 07 35 gtr
Sun Oct 02, 2016 4:23 pm |
jd44
Wish i had an old picture of it. But basically it was a sleeve that slipped on the shaft and had the same profile of the end of the original shaft. You had to put a bolt their the sleeve and the original shaft. I bought the motor in 2010 and it was on the oringial trim unit.
Sun Oct 02, 2016 4:45 pm |
mizzippi jb
That looks like an unnecessary hinge point that would make the trim do funny shit. Just my opinion
Sun Oct 02, 2016 4:47 pm |
jd44
Yes, that's exactly what it does. Puts the whole system in a bind. But it got me thru a weekend of hunting.
Sun Oct 02, 2016 5:15 pm |
GatorDubea
why not just bolt the shaft itself to that point instead of having the linkage ? I know you would loose some trim.
Tue Oct 04, 2016 11:58 am |
jd44
You can, but even with the pin in the highest hole you don't have enough trim to really run it in the right position. It will work that way, but you aren't getting the most out of the motor without being able to trim it high enough.
Tue Oct 04, 2016 12:10 pm |
