Diesel mud motor? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=68616 |
Author: | gguillory [ Wed Oct 12, 2016 12:36 pm ] |
Post subject: | Diesel mud motor? |
Who would like to see a diesel on the market? |
Author: | msm8281 [ Wed Oct 12, 2016 2:00 pm ] |
Post subject: | Re: Diesel mud motor? |
gguilory would!! Sent from my SAMSUNG-SM-G925A using Tapatalk |
Author: | Glade [ Wed Oct 12, 2016 2:06 pm ] |
Been there, done that. HP to weight doesn't work, and they shake like a jumping jack. |
Author: | gguillory [ Wed Oct 12, 2016 2:10 pm ] |
They do but there is some 10 HP that are under 60 lbs and if you go big HP to wt only gets better. I am curious as to wether they would get a good reception if one was produced that was competitive with the gas ones? |
Author: | cb5331 [ Wed Oct 12, 2016 2:11 pm ] |
Was it really necessary to start three different threads about this? |
Author: | gguillory [ Wed Oct 12, 2016 2:13 pm ] |
Author: | gguillory [ Wed Oct 12, 2016 2:15 pm ] |
Author: | BERNIE255 [ Wed Oct 12, 2016 5:34 pm ] |
[/quote] a product is only as good as the demand.[/quote] Theres no demand for a diesel mud motor, so the product ain't worth shit Sent from my iPhone using Tapatalk |
Author: | Russ [ Wed Oct 12, 2016 6:05 pm ] |
There's no demand for a diesel mudmotor, until there is one and it doesn't weigh a ton to produce good power. If it does the job better than what's there, isn't cost prohibitive, they might sell. Asking here with zero specifics other than something 10hp and some vague references to hp to weight gets better isn't going to garner positive comments. They're heavy for the power they provide. They have their application, but weight is a concern with mudmotors, so it's very unlikely to ever find a home in this realm. We can get 50+ hp out of a 140lb powerhead with some semblance of reliability. Match that, and you have something simply due to reliability advantages of a diesel. Good luck |
Author: | gguillory [ Wed Oct 12, 2016 6:57 pm ] |
I have a diesel engine, 3 cyl water cooled 270 lb that produces 61 HP and 174 ft lb tq, and a 60 lb 10 HP that I am thinking about trying to fit to drives. I was trying to see if people would be interested so i have an idea about the markets reception to it. Although I think it's cool, and could work it needs to be something that would sell eventually, and there's no better place to look for opinions on the subject than here I think. |
Author: | Russ [ Wed Oct 12, 2016 7:00 pm ] |
What rpms does that big diesel produce power at? |
Author: | cb5331 [ Wed Oct 12, 2016 7:23 pm ] |
That much weight, i'd rather have two motors. |
Author: | gguillory [ Wed Oct 12, 2016 7:51 pm ] |
At 3400 rpm. The weight isn't too far off of a twin package and it produces substantially more tq. It also burns 1.7 gph and has a service life of 8000 hrs. |
Author: | Quack N Stack [ Thu Oct 13, 2016 6:17 am ] |
You can build one of these bad boys and you might have something... http://youtu.be/TlfCiQTbOMg |
Author: | CypressCritter [ Thu Oct 13, 2016 8:28 am ] |
Just think with a diesel, you could "nitro" with propane, that would kick up the rpms and torque!! KICK THE TIRES AND THE FIRES!!!!! ![]() |
Author: | gguillory [ Thu Oct 13, 2016 8:41 am ] |
It is a high pressure common rail engine so a tune and those numbers go up... |
Author: | mucknaked [ Thu Oct 13, 2016 11:08 am ] |
You could not afford it. |
Author: | gguillory [ Thu Oct 13, 2016 11:37 am ] |
It's looking like its going to wind up costing 10-12000. So yes way up there. |
Author: | JIMMY W [ Thu Oct 13, 2016 12:22 pm ] |
A retard would love one! |
Author: | gguillory [ Thu Oct 13, 2016 2:32 pm ] |
OK OK, I think I have my answer! |
Author: | Russ [ Thu Oct 13, 2016 3:18 pm ] |
Don't pay him any mind, guillory. He's one of the resident mmt member that dementia has set in with. |
Author: | stualaska [ Sat Oct 15, 2016 11:44 am ] |
Been there, done that, threw away the t-shirt. It will work if the HP to weight ratio is better than the 3-cyl Kubota I used. Check out my blog. https://godevilalaska.wordpress.com/cat ... ace-drive/ |
