Jumped my mud motor with spinner batteries!
Well, yesterday we boated up river to our spot, turned off the motor (Briggs 36) and when we went to start it again a minute later, the battery was d - e - a - d, dead. We'd been running an LED light bar and a hand held spotlight, running for 30 minutes or so.
Not having a jump pack or spare battery, we thought we were SOL until we decided to take the 6V batteries out of a couple of spinners, wire them in series (creating a 12V battery) and voila! Got 'er going. So we decided to hunt. After the hunt, had to jump it again with the spinner batteries. So the moral here is that a couple of 3.5 amp hour spinner batteries will indeed get a big block Briggs started. We even googled how to wire batteries in series (vs in parallel) to make sure we were doing it right.
https://www.batterystuff.com/kb/article ... orial.html Now to troubleshooting my problem. Looking for input as to possible causes:
1) Bad alternator on the Briggs not charging the battery as we draw it down with accessories?
2) Corrosion at terminals preventing proper charging? They weren't exactly clean but they weren't massively corroded either.
3) Bad battery even though it is only a year old?
4) Low charge on the battery just enough for one start, but wouldn't the battery charge as I was running the motor at high RPM?
If any of the brain trust wants to give your opinion, I am all ears. I am going to get the motor started today and remove the battery leads, putting my multi-tester on them to see if I am getting a charge back toward the battery from the alternator. I also charged the battery when I got home yesterday, it began with only a 38% charge on it.
Thanks for any constructive advice.
