It is currently Sun Jun 22, 2025 6:32 pm
Reply to topic  [ 14 posts ]
 Pic of PD Console Ignition/PTO
Post Pic of PD Console Ignition/PTO
Can somebody please post a photo showing wiring orientation/location on a PD console ignition switch and PTO switch/momentary switch? Just need a picture showing which wires go where.
Thanks.
Wed Dec 21, 2016 11:14 am
Post Re: Pic of PD Console Ignition/PTO
Here you go Blu
viewtopic.php?f=3&t=51274
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Wed Dec 21, 2016 11:24 am
Thanks, Maxxis. Got a wire from the back of the PTO switch...pulled out of the packard spade. Finally found a replacement spade for it...just didn't remember which hole it came out of. The wiring diagram tells me it goes in the top corner...I'll give it a try.
Wed Dec 21, 2016 1:16 pm
Was that you calling me last weekend blu? I had no idea who i was talking to. :lol:
Wed Dec 21, 2016 1:22 pm
Not a problem Troy, get that thing back up and running!
Bayou Surface Drive
337-351-0362
Wed Dec 21, 2016 1:37 pm
Wed Dec 21, 2016 2:05 pm
I had your number saved at one point, but all my contacts got deleted a while back. I'll save it now. :lol:
Wed Dec 21, 2016 2:06 pm
Alright...this is the back of my PTO switch. I have a solid yellow wire...which slot does the packard spade connector go into?
Wed Dec 21, 2016 3:08 pm
Got the wire figured out. Engine starts, momentary engages, PTO switch does not engage clutch... but, prevents ignition from starting when pulled out.
PTO switch fried?
Wed Dec 21, 2016 4:58 pm
Bring it to dallas. I'll figure it out in about 10 minutes. :lol:
Wed Dec 21, 2016 5:03 pm
Sounds like it blu my pto switch did that a couple months ago
Sent from my SAMSUNG-SM-G890A using Tapatalk
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Wed Dec 21, 2016 6:29 pm
If you have a meter you can check continuity to verify it is bad
Wed Dec 21, 2016 6:31 pm
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Wed Dec 21, 2016 6:50 pm
Definitely fried the switch along with the clutch. Borrowed one from AKA to troubleshoot and the clutch engaged. Going give her a test run with a freshly worked prop and see if it all stays together.
Wed Dec 21, 2016 9:23 pm
Users browsing this forum: No registered users and 389 guests
