It is currently Mon Jun 23, 2025 1:04 am
Reply to topic  [ 13 posts ]
 lost all power no throttle response???
Post lost all power no throttle response???
I have a 2010 35hp godevil surface drive and last weekend i was out running with a full hunt load (9 doz deeks 4 guys about 150lbs each and a dog 100lbs) was running full throttle just on plane and motor was acting fine and then all the power suddenly cut off. we lost all throttle response but all the parts still moved at normal. lift the prop out of the water and i takes about 10 seconds of buildup to get any decent rpms out of it. and as soon as you drop it back in it goes straight back to idle. What could be wrong cause i have no clue.
Mon Dec 05, 2016 1:44 pm
Post Re: lost all power no throttle response???
So, the engine shut down all at once? Or engine still running and getting good RPMs but propeller not turning?
2013 GatorTrax 1750 Sport Hybrid W/ Hunt Deck
2013 Mud Buddy 35 HD Sport
Mon Dec 05, 2016 2:10 pm
Mon Dec 05, 2016 2:16 pm
Put eyes on throttle shaft at carb and make shure its all good when running
Mon Dec 05, 2016 3:20 pm
Water in fuel?
Mon Dec 05, 2016 3:21 pm
Tue Dec 06, 2016 7:05 am
I had something similar happen to mine but it was the rev limiter. It got wet and shit the bed. I'd check that/take it off and see if it runs fine if you have one.
Gatortail Extreme 1854 w/ GTR 37 efi or 90hp Yamaha
Godevil 1860 w/ gd 35 sd with a Mikuni Carb Sold
Tue Dec 06, 2016 7:10 am
Exact same thing happened to me last year. It was a disconnected rod.
Wed Dec 07, 2016 10:58 am
Make sure it isn't running on one cylinder. Pull spark plugs one at a time to see if motor dies.
If it does die pull valve covers and see whats going on inside.
Kool-Aid Brigade
www.southernfowler.com
Wed Dec 07, 2016 11:16 am
Twice my Prodrive 36 while at WOT died. Out of the water it ran fine, turned the right rpms and sounded fine. Put it in the water and it would only run about 5 mph, or a little higher than idle. Both times a push rod had jumped out of place. Easy fix by putting back in place and adjusting valves. Hope this is all that's wrong with yours and what ever it is, is an easy fix. By the way, this is caused from not keeping the valves adjusted (I think).
Thu Dec 08, 2016 10:35 am
Fri Dec 09, 2016 12:19 pm
Good deal!
Fri Dec 09, 2016 12:22 pm
Fri Dec 09, 2016 2:06 pm
Users browsing this forum: Majestic-12 [Bot] and 450 guests
