lost all power no throttle response???
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=69158
Author:  duckrunner99 [ Mon Dec 05, 2016 1:44 pm ]
Post subject:  lost all power no throttle response???
I have a 2010 35hp godevil surface drive and last weekend i was out running with a full hunt load (9 doz deeks 4 guys about 150lbs each and a dog 100lbs) was running full throttle just on plane and motor was acting fine and then all the power suddenly cut off. we lost all throttle response but all the parts still moved at normal. lift the prop out of the water and i takes about 10 seconds of buildup to get any decent rpms out of it. and as soon as you drop it back in it goes straight back to idle. What could be wrong cause i have no clue.
Author:  Rosstree27 [ Mon Dec 05, 2016 2:10 pm ]
Post subject:  Re: lost all power no throttle response???
So, the engine shut down all at once? Or engine still running and getting good RPMs but propeller not turning?
Author:  duckrunner99 [ Mon Dec 05, 2016 2:16 pm ]
Author:  Will C [ Mon Dec 05, 2016 3:20 pm ]
Put eyes on throttle shaft at carb and make shure its all good when running
Author:  Will C [ Mon Dec 05, 2016 3:21 pm ]
Water in fuel?
Author:  Rosstree27 [ Tue Dec 06, 2016 7:05 am ]
Author:  xYouAreBoyx [ Tue Dec 06, 2016 7:10 am ]
I had something similar happen to mine but it was the rev limiter. It got wet and shit the bed. I'd check that/take it off and see if it runs fine if you have one.
Author:  Quack N Stack [ Wed Dec 07, 2016 10:58 am ]
Exact same thing happened to me last year. It was a disconnected rod.
Author:  3rd Coast Killer [ Wed Dec 07, 2016 11:16 am ]
Make sure it isn't running on one cylinder. Pull spark plugs one at a time to see if motor dies.
If it does die pull valve covers and see whats going on inside.
Author:  wireworks [ Thu Dec 08, 2016 10:35 am ]
Twice my Prodrive 36 while at WOT died. Out of the water it ran fine, turned the right rpms and sounded fine. Put it in the water and it would only run about 5 mph, or a little higher than idle. Both times a push rod had jumped out of place. Easy fix by putting back in place and adjusting valves. Hope this is all that's wrong with yours and what ever it is, is an easy fix. By the way, this is caused from not keeping the valves adjusted (I think).
Author:  duckrunner99 [ Fri Dec 09, 2016 12:19 pm ]
Author:  Will C [ Fri Dec 09, 2016 12:22 pm ]
Good deal!
Author:  Quack N Stack [ Fri Dec 09, 2016 2:06 pm ]
