BlueShamu
 Pic of PD Console Ignition/PTO
Can somebody please post a photo showing wiring orientation/location on a PD console ignition switch and PTO switch/momentary switch? Just need a picture showing which wires go where.
Thanks.
Wed Dec 21, 2016 11:14 am |
MaXXis85
 Re: Pic of PD Console Ignition/PTO
Wed Dec 21, 2016 11:24 am |
BlueShamu
Thanks, Maxxis. Got a wire from the back of the PTO switch...pulled out of the packard spade. Finally found a replacement spade for it...just didn't remember which hole it came out of. The wiring diagram tells me it goes in the top corner...I'll give it a try.
Wed Dec 21, 2016 1:16 pm |
cb5331
Was that you calling me last weekend blu? I had no idea who i was talking to.
Wed Dec 21, 2016 1:22 pm |
MaXXis85
Not a problem Troy, get that thing back up and running!
Wed Dec 21, 2016 1:37 pm |
BlueShamu
Wed Dec 21, 2016 2:05 pm |
cb5331
I had your number saved at one point, but all my contacts got deleted a while back. I'll save it now.
Wed Dec 21, 2016 2:06 pm |
BlueShamu
Alright...this is the back of my PTO switch. I have a solid yellow wire...which slot does the packard spade connector go into?
Wed Dec 21, 2016 3:08 pm |
BlueShamu
Got the wire figured out. Engine starts, momentary engages, PTO switch does not engage clutch... but, prevents ignition from starting when pulled out.
PTO switch fried?
Wed Dec 21, 2016 4:58 pm |
cb5331
Bring it to dallas. I'll figure it out in about 10 minutes.
Wed Dec 21, 2016 5:03 pm |
teammarshmafia
Joined: Tue May 14, 2013 2:18 pm Posts: 478 Location: southeast, Louisiana
Sounds like it blu my pto switch did that a couple months ago
Sent from my SAMSUNG-SM-G890A using Tapatalk
_________________ Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom Jus nut up and grab a handful of throttle
Wed Dec 21, 2016 6:29 pm |
teammarshmafia
If you have a meter you can check continuity to verify it is bad
Wed Dec 21, 2016 6:31 pm |
JLACOUR
Joined: Wed Jan 14, 2009 8:18 pm Posts: 4915 Location: Lake Jackson, TX
_________________ 37 PD EFI FPR 18x48 Tiller SOLD -- 36 PD EFI FPR 18x48 Stick Steer SOLD -- 27 PD FPR 16x36 Skiff
Wed Dec 21, 2016 6:50 pm |
BlueShamu
Definitely fried the switch along with the clutch. Borrowed one from AKA to troubleshoot and the clutch engaged. Going give her a test run with a freshly worked prop and see if it all stays together.
Wed Dec 21, 2016 9:23 pm |
