It is currently Sun Jun 22, 2025 10:14 pm
Reply to topic  [ 7 posts ]
 04 Gatortail 35. Electric clutch not engaging. UPDATE. FIXED
Post 04 Gatortail 35. Electric clutch not engaging. UPDATE. FIXED
No other issues. Cranks and runs fine. Trims up and down. Just when I pull the switch to engage and put in gear, I get nothing. No clicking or anything.I bypassed the switch and got nothing. I can see the plate behind the drive gear and center nut turning all the time. I can turn the cog belt and gears easily by hand. TIA.
Sun Dec 18, 2016 8:41 am
Post Re: 04 Gatortail 35. Electric clutch not engaging.
Sounds like you've just got a wore out clutch. I would bypass switch (Like you've said) and make sure all connections are tight. If not, try out another clutch and see if that one works.
Mon Dec 19, 2016 3:02 am
Thanks I've got a couple of things to look at electrically and then I guess I'll start swapping out the clutch.
Mon Dec 19, 2016 7:04 pm
If that's the original clutch, I would think its time for a new one.
Never know until you start tearing down shit!
Mon Dec 19, 2016 7:17 pm
Post Re: 04 Gatortail 35. Electric clutch not engaging. UPDATE. F
Red wire from ignition that feeds the switch wasn't plugged in. I had replaced my fuel lines and pulled my carb. The wire must have come loose when I pulled the ignition panel.
Wed Dec 21, 2016 5:16 pm
Wed Dec 21, 2016 5:30 pm
Yeah thanks. Me too. The clutch was working fine when I replaced all my fuel lines a few weeks ago. I was standing behind the boat when starting it and could see the back of the ignition switch and the red wire wasn't connected to anything and I could see a bare connector plug on the ignition. I plugged it in and BAM, it started working like new.
Thanks for the responses.
Wed Dec 21, 2016 5:54 pm
Users browsing this forum: No registered users and 446 guests
