Freedom outboards http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=70077 |
Author: | Quack N Stack [ Sat Mar 18, 2017 5:36 am ] |
Post subject: | Freedom outboards |
I guess if its on Facebook it must be true! IMG_1105.JPG Sent from my iPhone using Tapatalk |
Author: | Darryle [ Sat Mar 18, 2017 5:47 am ] |
Post subject: | Re: Freedom outboards |
I never was the juiciest raisin in the box, so explain how that differs from a traditional outboard. I am guessing it's a water cooled upper retrofitted to a surface drive lower? Or vise versa? |
Author: | CypressCritter [ Sat Mar 18, 2017 7:22 am ] |
Too bad that camo doesn't match my boat! The cooling system is mounted inside the boat. Read somewhere that its a Tohatsu outboard with a modified lower unit without a water pickup, because of the closed loop cooling system. |
Author: | flint87 [ Sat Mar 18, 2017 8:09 am ] |
How the fuck you gonna throw a rooster tail and shit on all the poor people with that mail box cav plate? Sent from my iPhone using Tapatalk |
Author: | Quack N Stack [ Sat Mar 18, 2017 12:55 pm ] |
They have a website up with alot of info on them now. Says on their website that they are the shit and better than any other "old style" surface drive in every aspect...think it also said they are way tougher than any others available..they should send me one to test, i give it a few hours. Ive been known to break things..... https://www.freedom-outboard.com/freedo ... rd-motors/ |
Author: | dem0001 [ Sat Mar 18, 2017 6:19 pm ] |
Price??? Sent from my iPhone using Tapatalk |
Author: | Darryle [ Sat Mar 18, 2017 6:29 pm ] |
From the link: Features 267 lbs total weight Closed loop cooling Lockable floating Jack plate Multi prop compatibility to enable max performance with almost any type of boat and load Steering brake to aid in reducing torque steer Twist-grip throttle Break away prop hub to prevent gear case damage Hydraulic power trim Hydraulic 5-1/2 inch jack plate to enable prop to be lowered or raised to suit conditions Lower unit front bumper Horizontal beams to aid in protecting the prop from damage and provide lift Full coverage cavitation plate to aid in getting up on plane quicker while reducing torque steer The largest Mud prop in the industry: 11.0 x 16 – 3 blade Largest horsepower stock motor produced 6200 RPM motor Automotive style radiator and cooling fan Enclosed engine Enclosed controls Zinc anodes throughout the assembly to prevent corrosion Remote steer available Meets all coast guard safety requirements for an outboard Weed-less Mud prop by Hopkins Propeller Service Conventional SS prop By Tohatsu https://youtu.be/XdHXi9c-cT0 |
Author: | RootSumn [ Sat Mar 18, 2017 7:43 pm ] |
Damn, I like that chair! |
Author: | Mallards Only [ Mon Mar 20, 2017 8:15 am ] |
Notice how not a single video shows the inside of the boat and the cumbersome cooling system? |
Author: | CypressCritter [ Mon Mar 20, 2017 8:23 am ] |
Author: | 4Cody4 [ Mon Mar 20, 2017 9:16 am ] |
I'd like all the details on this thing though. I even like this more than that Hoss drive. Seems most practical and most quiet. Sent from my iPhone using Tapatalk |
Author: | CypressCritter [ Mon Mar 20, 2017 9:41 am ] |
Author: | 4Cody4 [ Mon Mar 20, 2017 11:55 am ] |
Exactly, plus I want to stay with a tiller. This thing is headed in the direction I'm most interested in at the moment. Any way you look there are good things happening. Sent from my iPhone using Tapatalk |
Author: | Quack N Stack [ Mon Mar 20, 2017 1:09 pm ] |
If all your your running is soft bottom marsh where theres not much stumps or logs to hit I think it would be the caddy of duck boats...i dont think it would last a day in a stumpy environment. |
Author: | 4Cody4 [ Mon Mar 20, 2017 1:36 pm ] |
We run pretty clean stuff for the most part. I don't worry at all with my current motor when I hit logs or stumps, I'd be concerned with that freedom. I think it'd work most of the time, but that every so often I'd hate to be tearing stuff up. Sent from my iPhone using Tapatalk |
Author: | Darryle [ Mon Mar 20, 2017 2:39 pm ] |
Author: | Bigbend [ Mon Mar 20, 2017 2:42 pm ] |
Is that a beer can with a mudboat on it in that pic |
