Mud buddy trim quit
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=70120
Author:  Scoggins [ Sat Mar 25, 2017 4:34 am ]
Post subject:  Mud buddy trim quit
Need help suggestions please
Author:  flint87 [ Sat Mar 25, 2017 11:34 am ]
Post subject:  Re: Mud buddy trim quit
Here I will help you.
I suggest you describe what is going on with your trim unit so that someone can know how to help you.
Author:  Bigbend [ Sat Mar 25, 2017 11:53 am ]
If it quit working I'd probably just fix it.
Author:  DENNYEDWARDS [ Sat Mar 25, 2017 5:15 pm ]
I'd start with the rocker trim switch in the football to make sure wiring was ok. Next I would check up and down relays to trim unit. Next the circuit breaker to trim motor. Then I would check the trim motor by reversing wires from it to a battery to see if it goes up and down. A multimeter comes in handy when checking switches and wiring. If all else fails take it to a dealer.
Author:  Scoggins [ Sun Mar 26, 2017 11:26 am ]
Author:  BERNIE255 [ Sun Mar 26, 2017 1:04 pm ]
Did you check the inline bus fuse?
Author:  Scoggins [ Sun Mar 26, 2017 3:48 pm ]
[quote="BERNIE255"]Did you check the inline bus fuse?
Don't know that there is one, if so I'm not sure where it's at
Author:  BERNIE255 [ Tue Mar 28, 2017 4:59 pm ]
What trim do you have
Author:  Scoggins [ Wed Mar 29, 2017 7:15 pm ]
Mercury
Author:  Scoggins [ Thu Mar 30, 2017 6:57 pm ]
It was a circuit breaker
The original was a 20 amp was told to replace with a 40 amp
Should not be a problem any more but I'll keep a jumper wire just in case
