It is currently Sat Jun 21, 2025 7:43 pm
[ 6 posts ] |
mudder
Joined: Sun Jan 25, 2009 11:25 am Posts: 401 Location: Wisconsin
 Prodrive back fire
What typically causes a backfire. Motor runs great, but backfires when I shut motor off and immediately turn it back on. If I were to wait a minute b4 starting it up, it typically does not.
Was thinking of cleaning the carb, but I just did that 2 years ago and have really had no issues with the carb. Motor idles perfectly at around 1100 RPMs.
I always use new gas, has new gas line, and after disconnecting the fuel lines for storage I throw the old gas in the truck in the spring.
Motor has around 340 hrs.
Just wondering.
Thanks
_________________ Phowler Extreme 1848 with 36PDFPR
Wed May 10, 2017 9:51 am |
cb5331
 Re: Prodrive back fire
Sucking cool air back up in the heads through a blown exhaust gasket can cause that.
Wed May 10, 2017 9:55 am |
Russ
As can the engine just not quite getting enough fuel on that last (on shut off) or first (cranking it so quickly after shutting it off) burn cycle (effectively a lean condition, but nothing to worry about).
Sent from my SAMSUNG-SM-G891A using Tapatalk
Wed May 10, 2017 9:58 am |
mudder
Wed May 10, 2017 10:06 am |
mudder
Wed May 10, 2017 10:08 am |
cb5331
Cool.
Wed May 10, 2017 10:09 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 366 guests |
