boat speed http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=70451 |
Author: | toadman41 [ Sun May 21, 2017 2:38 pm ] |
Post subject: | boat speed |
i bought a 1760 lowe roughneck boat with a godevil 35hp surface drive motor. with two guys open water i only get 15 mph no matter how deep or shallow i set the prop .any help or suggestions would be needed. |
Author: | Russ [ Sun May 21, 2017 4:44 pm ] |
Post subject: | Re: boat speed |
Rpms? Lots of variables but that'll get the crowd started Sent from my SAMSUNG-SM-G891A using Tapatalk |
Author: | toadman41 [ Sun May 21, 2017 5:00 pm ] |
does not matter if i get 3700 3800 or 3900 rpm still the same speed. |
Author: | Russ [ Sun May 21, 2017 5:47 pm ] |
Where you located? Sent from my SAMSUNG-SM-G891A using Tapatalk |
Author: | toadman41 [ Sun May 21, 2017 7:19 pm ] |
topeka,kansas |
Author: | flint87 [ Sun May 21, 2017 8:21 pm ] |
I'm going with mod v hull. Am I right? Sent from my iPhone using Tapatalk |
Author: | brycecheramie [ Mon May 22, 2017 4:15 am ] |
Author: | Smoke [ Mon May 22, 2017 4:28 am ] |
Check prop size and wear. You should be running better than that regardless of hull unless its hooked to shit. I would say low 20's with a stock motor light load. If you are only turning 3800 rpms you are leaving a lot of rpms in the motor yet. Should be able to turn that stock motor/carb to 4100-4200. Are you getting a rooster tail when you are running? |
Author: | flint87 [ Thu May 25, 2017 8:33 am ] |
Author: | Exbellicus [ Thu May 25, 2017 8:39 am ] |
Can you tell us a little more about the motor? New/used, hours, mods, condition, etc. Any odd noises, does it sound like it is bogging out? Are you getting on a plane @ 15. Also not trying to be a dick but want to make sure you are trimming it up high enough to run like a mud motor should - with the prop about half way out of the water (not completely submerged like an outboard). Are you getting a 'rooster tail' at 15? |
Author: | WhoDat88 [ Thu May 25, 2017 4:12 pm ] |
Is your prop wrong? Do you have a tall transom motor on a short transom hull? Not the best hull for a surface drive but you should be seeing better speeds |
Author: | 50fps [ Thu May 25, 2017 7:10 pm ] |
