I am trying to install LED lights under the gunnel rails of the boat. The problem I am having is trying to route the wiring to the control panel. Because of the foam and angles I cannot get the wire routed. Anyone have any suggestions or experience they could share?
_________________ Rockben
Sat Nov 25, 2017 12:10 pm
DENNYEDWARDS
Joined: Sun Aug 09, 2009 12:50 pm Posts: 574 Location: Muscatine, Iowa
Re: Excel F4 Wiring for LED and Sound bar
Might try a shop vac and string to suck pull string thru gunnel rail.
Sat Nov 25, 2017 1:09 pm
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
Under or thru? I used a length of electric fence wire doubled, be sure a push the loop end first) tied some trot line string to that with enough length to pull wire thru and then pull string back and then pulled more thru!
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Users browsing this forum: Majestic-12 [Bot] and 352 guests
