It is currently Fri Jun 20, 2025 1:46 pm
Reply to topic  [ 26 posts ]
 Block swap help!
Post Block swap help!
So I’m looking to slap a new 37efi on my mudbuddy frame! My first question is will it fit? And my second question is I was looking on brandnewengines.com and I see there are two different 37efi. On is more and one is less. What one would I get to make it fit right
Mon Apr 02, 2018 8:06 pm
Post Re: Block swap help!
61e477 is the model normally used. Not sure of the difference between the 377 and 477. If Marcus or will don't chime in before I find the answer, I'll post it here.
#TheGhostBoat
Mon Apr 02, 2018 8:39 pm
Mon Apr 02, 2018 8:52 pm
You are both correct. Also the 61e377 says it has a 3600 or 4000 governer. We buy the 61e477's
Mon Apr 02, 2018 10:33 pm
477 have the 4800 limiter like Will said. They have the same footprint as the big blocks. Also beware of crankshafts. Hens I don't recommend buying from online sites that don't help you get the right engine.
Tue Apr 03, 2018 6:30 am
Tue Apr 03, 2018 7:31 am
Considering they say it's a 1 1/8x4, you're probably good. But like maxxis said, they don't really care if it works like he or one of the manufacturers would. Shoot him a pm and see what his price to you would be.
#TheGhostBoat
Tue Apr 03, 2018 7:54 am
Marcus could probably get you the "right engine the first time" for close to the same price you will pay online.
Cause you don't want to have to deal with sending the motor back cause something is wrong and all that BS.
Refurbishing a Prodrive
Tue Apr 03, 2018 8:03 am
Tue Apr 03, 2018 8:46 am
:lol: :lol:
Yeahhhhh that may be an issue.
Tue Apr 03, 2018 8:47 am
Years ago there was two out put shaft lengths, may want to check your old motor for correct lenght when ordering. Older motors with out clutches had the shorter crank out put shafts.
Tue Apr 03, 2018 8:59 am
Tue Apr 03, 2018 9:18 am
Tue Apr 03, 2018 10:37 am
I bought my new powerhead straight from a briggs dealer last summer and installed it myself.
Tue Apr 03, 2018 10:51 am
Might be a dumb question but how’s the dealer gonna know what one I need? What do I need to ask for for him to get me the right motor for a problem free swap. Motor is a 2014 5500 hd
Tue Apr 03, 2018 1:53 pm
I walked in with the model # and he placed the order. They know nothing about mud motors. Even if you leave it stock, once it's on a frame it may as well be an aircraft engine to them.
Tue Apr 03, 2018 3:18 pm
i bought my 35 marine from brandnewengines.com. 613477. 3 year briggs warranty and came with stainless stock muffler. measure the crank check the specs of the motor you want and get it coming.
i check with my local dealers and the they knew less that the guys that BNE.com. the dealer wanted to know what mower it was on even with the model number in hand. :roll:
GOOD LUCK
Tue Apr 03, 2018 6:14 pm
Tue Apr 03, 2018 7:25 pm
Yep ordering it tomorrow. Took motor off the frame tonight crank measures up to be the same as the 37efi per Briggs measuring specs so I think I’m good to go! Thanks for all the help
Tue Apr 03, 2018 10:04 pm
Also i did just relize I’m going from a modded motor down to a 37efi and I have a hammer prop on it.... is this thing gonna be able to turn it effectively? If it can haul a load but run a little slower I’m ok with that for the bowfishing season but if not I’m gonna need to jump to a new prop. What do you guys think
Tue Apr 03, 2018 11:49 pm
Sat Apr 07, 2018 8:56 am
Sat Apr 07, 2018 10:07 am
There have been a couple take possession of the new 40efi, maybe someone can drop a type #. I just looked at Briggs Industrial engine web page and it's not on there yet. Seeing as manufacturers are getting them, don't see why one can't be found.
Sat Apr 07, 2018 12:15 pm
61G477
Mon Apr 09, 2018 8:49 am
Mon Apr 09, 2018 9:00 am
that's for the new 40 hp
Mon Apr 09, 2018 9:03 am
Users browsing this forum: No registered users and 142 guests
