It is currently Mon Dec 22, 2025 11:32 am
Reply to topic  [ 10 posts ]
 Go-Devil to Tin Can Thoughts
Post Go-Devil to Tin Can Thoughts
I'm currently running a 1648 GDSD Hull and a 35hp GDLT. I'm thinking about downsizing to a lighter weight setup.
Is there much difference in performance for a 23hp copperhead on riveted hulls from 1542-1748? I typically hunt with a 2nd but would like something I can hunt alone with. We have a portage/pullover so weight is a bit of an issue.
Also, any recommendations on some lightweight open layout riveted or mud hulls I should check into would be greatly appreciated.
Sent from my SM-G930V using Tapatalk
Tue Sep 11, 2018 6:11 pm
Post Re: Go-Devil to Tin Can Thoughts
Honestly all depends on what kinda conditions you run.
If you run stumps, the tin can will not hold up for a long time.
If you run mud and open shallow water, tin can will be fine
Tue Sep 11, 2018 6:30 pm
Find you an old ouchita and it will lay you and do all you want it to bud
Tue Sep 11, 2018 6:51 pm
Not much for stumps where I am. Mostly just some bullrush and shalows. Would the copperhead run better with a 1744 compared to a 1544?
Tue Sep 11, 2018 9:11 pm
The copperhead is great if you keep it light. Great for rivet boats. 1544 would be good. 1744 maybe if it's very light. We have a 1448 rivet 23 copperhead. Love it.
Wed Sep 12, 2018 3:52 am
My 9 yr. old 1648 riveted Alumacraft weighed 290 lbs. Empty. I would think a 1448 would weigh less than that. I use mine to ferry upto 5 hunters back and forth to our pontoon blind. Motor is a MB 45. A 18-23 HP Mud motor would push a 1448 really well. With two people and gear.
Wed Sep 12, 2018 5:53 am
Thank you for the replies. Some of the numbers I've seen for those rigs are impressive.
Tue Sep 18, 2018 10:13 pm
Just sold the Go-Devil to a friend and picked up a 1542 Grumman Scrambler (210 lbs) and found a used 2016 23hp Copperhead to put on it. That sucker flies with the copperhead. I was getting about 27-28 mph with an empty boat.
Will C, when I get above half throttle I start getting some pretty bad vibration. Do you experience that at all? When I go full throttle out of the water, no real vibration. Is caused by an unbalanced prop?
Mon Oct 01, 2018 10:17 am
Unbalanced prop bro. Send it to baggy in Houma and he will get it dialed in right
Mon Oct 01, 2018 11:06 am
Thanks Wchauvin. I talked to Josh at Copperhead and he said to check the belt tension, which was a bit loose so I shimmed it 1/32 which improved the vibration some. I might try find a more local place to balance the prop.
Wed Oct 03, 2018 6:12 pm
