It is currently Fri Jun 20, 2025 9:28 am
Reply to topic  [ 2 posts ]
 '15 Prodrive 37 EFI won't turn over
Post '15 Prodrive 37 EFI won't turn over
Just bought a 2015 37 EFI and I can't get it to turn over at all. Had battery checked and charged. Checked fuse between the tiller handle and the block, all good. Prop spins both ways, so I think the clutch swith is good. Just can't get anything when I turn the key. Help!
Mon Oct 01, 2018 8:27 am
Post Re: '15 Prodrive 37 EFI won't turn over
Speak to Prodrive Monday. You can get a wiring diagram.
Make sure your kill switch is working properly and that you do not have something grounding your engine. If your motor "thinks" it's in gear she will not start. Or if your ill switch is pulled.
Sat Oct 20, 2018 9:58 am
Users browsing this forum: Google [Bot] and 157 guests
