It is currently Fri Jun 20, 2025 5:22 am
[ 4 posts ] |
Gatortail 35hp Gen 4 Caliper Reverse Question
cut'em94
Joined: Tue Oct 02, 2012 6:16 pm Posts: 291 Location: Luling, LA
I recently upgraded to the gen 4 calipers and bled the line as recommended in gatortails manual. When i squeeze the reverse handle, it goes pretty much all the way to the handle. The brake pads are closing on the rotor when i squeeze the reverse lever but it doesnt seem to have as much pressure as the gen 3 calipers i had. Is this normal for the gen 4s? I seem to remember with the gen 3 that when i would squeeze the lever, it would not get close to the handle.
Sat Mar 16, 2019 6:29 pm |
jc
 Re: Gatortail 35hp Gen 4 Caliper Reverse Question
Sounds like you still have some air. Try bleeding it some more.
Sat Mar 16, 2019 7:03 pm |
cut'em94
Yep thats what it was. This may help someone else but i found the best way to bleed it is take the caliper off the mount, put it as low as possible, put the bleeder at the top, and it bled the little bit of air i still had in there quickly.
Sat Mar 16, 2019 7:59 pm |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
The gen 4 is a dual piston, which no matter what you do will have some give on first pump. Just do a couple squeezes and hold, your good. As for bleeding either caliper high or low just put bleed valves up and pump away.
Sent from my SM-N950U using Tapatalk
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
Mon Apr 01, 2019 9:09 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 115 guests |
