It is currently Wed Jan 14, 2026 11:17 am
[ 4 posts ] |
bluesky2012
 GT tilt bar removal
I’ve got my powerhead off for a cam swap and figured I should go ahead and replace the tilt bar bolt because mine has quite a bit of play. It’s definitely wallowed out a bit inside so it’s stuck in there good. Gave it a few hits and it won’t budge, so does anyone have a creative method to get it out?
| Sat Jun 01, 2019 10:49 am |
lastchance
Joined: Wed Feb 09, 2011 1:56 pm Posts: 1646 Location: Chauvin
 Re: GT tilt bar removal
Check your pm's
Sent from my SM-G975U using Tapatalk
| Sun Jun 02, 2019 11:13 am |
MaXXis85
the swivel bracket will have cut grooves in it. You need to support frame then work it out. Hitting it wont always be the best way.
| Mon Jun 03, 2019 7:12 am |
bluesky2012
Took an impact and a big freakin mallet but it’s out and replaced. Definitely worth replacing far more frequent than I did. Only $23 to replace.
| Fri Jun 07, 2019 9:19 pm |
[ 4 posts ] |
