It is currently Tue Jun 04, 2024 1:05 am
[ 4 posts ] |
bluesky2012
GT tilt bar removal
I’ve got my powerhead off for a cam swap and figured I should go ahead and replace the tilt bar bolt because mine has quite a bit of play. It’s definitely wallowed out a bit inside so it’s stuck in there good. Gave it a few hits and it won’t budge, so does anyone have a creative method to get it out?
Sat Jun 01, 2019 10:49 am |
lastchance
Joined: Wed Feb 09, 2011 1:56 pm Posts: 1646 Location: Chauvin
Re: GT tilt bar removal
Check your pm's
Sent from my SM-G975U using Tapatalk
Sun Jun 02, 2019 11:13 am |
MaXXis85
the swivel bracket will have cut grooves in it. You need to support frame then work it out. Hitting it wont always be the best way.
Mon Jun 03, 2019 7:12 am |
bluesky2012
Took an impact and a big freakin mallet but it’s out and replaced. Definitely worth replacing far more frequent than I did. Only $23 to replace.
Fri Jun 07, 2019 9:19 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 171 guests |
