It is currently Sun Mar 22, 2026 7:09 am
Reply to topic  [ 4 posts ]
 GT tilt bar removal
Post GT tilt bar removal
I’ve got my powerhead off for a cam swap and figured I should go ahead and replace the tilt bar bolt because mine has quite a bit of play. It’s definitely wallowed out a bit inside so it’s stuck in there good. Gave it a few hits and it won’t budge, so does anyone have a creative method to get it out?
Sat Jun 01, 2019 10:49 am
Post Re: GT tilt bar removal
Check your pm's
Sent from my SM-G975U using Tapatalk
Sun Jun 02, 2019 11:13 am
the swivel bracket will have cut grooves in it. You need to support frame then work it out. Hitting it wont always be the best way.
Mon Jun 03, 2019 7:12 am
Took an impact and a big freakin mallet but it’s out and replaced. Definitely worth replacing far more frequent than I did. Only $23 to replace.
Fri Jun 07, 2019 9:19 pm
