Prodrive heads job http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=73897 |
Author: | Pinhead pat [ Tue Jun 11, 2019 10:02 am ] |
Post subject: | Prodrive heads job |
I had to take my heads off my prodrive because i fucked up the threads where the exhaust bolts on one of them. Upon further inspection i found a big ol crack in that same head, i also cracked the other head where the intake manifold stud screws in. While ive got the heads off im wondering what else should i check and if anyone with better knowledge sees anything wrong with the pictures of my cylinders/ pistons? The pistons are covered in carbon i didnt know if i should clean them or how to clean them. Sent from my iPhone using Tapatalk |
Author: | brycecheramie [ Tue Jun 11, 2019 11:18 am ] |
Post subject: | Re: Prodrive heads job |
You'll probably have to replace that cracked head. I would recommend that you don't try to mess with them too much more. Seems like every time you mess with it, something gets broken ![]() |
Author: | Will C [ Tue Jun 11, 2019 1:34 pm ] |
You can grab a new set of stock heads for about 400 |
Author: | MaXXis85 [ Wed Jun 12, 2019 4:56 am ] |
Author: | Wchauvin [ Wed Jun 12, 2019 5:28 am ] |
“They are seasoned” ![]() |
Author: | Russ [ Wed Jun 12, 2019 6:44 am ] |
I've hot a set on the shelf, seasoned. 500 ![]() #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
Author: | Russ [ Wed Jun 12, 2019 6:45 am ] |
Got* #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
Author: | Pinhead pat [ Wed Jun 12, 2019 2:50 pm ] |
Author: | Pinhead pat [ Wed Jun 12, 2019 2:51 pm ] |
So the blackness of the pistons should jot worry me? Sent from my iPhone using Tapatalk |
Author: | brycecheramie [ Thu Jun 13, 2019 5:15 am ] |
Author: | dead animal [ Fri Jun 14, 2019 9:57 am ] |
don't worry about that little bit of blackness on the piston, that's normal. them heads crack like yours did over time, I have several just like it laying on the ground in my boatshed. lol just get a new set of heads and slap it back together and go cut some grass, oops, I mean go fishing with your boat. |
