It is currently Wed Oct 14, 2026 6:04 pm
Reply to topic  [ 8 posts ]
 Gator tail grt frame
Post Gator tail grt frame
Looking to upgrade boat hulls in the future. My current hull has a short transom would like to get one with a tall transom. But would like to keep my current motor. Just curious if I can change the frame? I know you can do that if I would have had a mud buddy. Just wondering if I would have to find one second hand? Also read in my search that gator tail doesn’t offer a frame change option due to liability.
Sun Sep 01, 2019 4:50 am
Post Re: Gator tail grt frame
You can get a tall transom belt housing and belt. You dont change the whole frame.
#GhostBoat
Sun Sep 01, 2019 11:11 am
It’s not hard, but go ahead and pre/soak those nuts and have heat on standby. Galvanic corrosion will make those frame segments tight to remove but it can be done.
Sun Sep 01, 2019 1:08 pm
Sun Sep 01, 2019 7:57 pm
Sun Sep 01, 2019 9:03 pm
Thanks everyone for the helpful replies they are very much appreciated.
Mon Sep 02, 2019 2:47 am
While you have it disassembled, if you have a 45 tooth gear on the out drive, get a 48 tooth gear and 48 tooth belt housing!
Sent from my SM-G975U using Tapatalk
Mon Sep 02, 2019 8:00 am
Mon Sep 02, 2019 12:01 pm
