It is currently Fri May 24, 2024 10:38 am
[ 8 posts ] |
Nickymalin
Fuel additives
Anyone have thoughts on these? Any particular brands they recommend or avoid?
Mon Nov 16, 2020 10:38 am |
bluesky2012
Re: Fuel additives
Seafoam
Mon Nov 16, 2020 10:50 am |
Russ
Re: Fuel additives
Agreed. Have used the same fuel without adding fresh gas after letting the tank sit from feb to june or july to october, with no issues and I don't run ethanol free. Fuel line gets replaced every 2 years whether it needs it or not, but I've never found bad gas in the carb bowl during my preseason checks, nor gunk buildup. I top off the tank when I hook up to the boat for use, and just let it sit when I'm done. Make sure you have a good fuel filter and run seafoam in every tank, should keep things nice and clean. No need to overuse, either. I run the amount listed on the bottle except for the last tank of the season when it's going to sit up, I double it.
#CFFITR #mudmotor>physics
Mon Nov 16, 2020 12:06 pm |
Bigbend
Re: Fuel additives
I use seafoam and stabil. I also only use ethanol free gas. Even though ethanol free gas doesn't have the water and phase separation issues as E10, any unleaded gas will varnish a carburetor if it sits up for a long time.
Mon Nov 16, 2020 1:31 pm |
bluesky2012
Re: Fuel additives
Also, Heet is solid for water in fuel (per project farm on YouTube so take that as you want). At like $2 a bottle I add some most every time just to be careful.
Mon Nov 16, 2020 2:32 pm |
Wchauvin
Re: Fuel additives
Mon Nov 16, 2020 8:05 pm |
bluesky2012
Re: Fuel additives
Mon Nov 16, 2020 10:35 pm |
Russ
Re: Fuel additives
Mon Nov 16, 2020 10:47 pm |
[ 8 posts ] |
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 137 guests |
