It is currently Sun Jun 09, 2024 9:52 am
[ 2 posts ] |
Heads Up-Pot. Problem with Briggs Heads!
XGEN-DUCKMAN
Joined: Fri Jan 16, 2009 3:51 pm Posts: 195 Location: BackWaters of Wisconsin
Was helping Mudd set the Valve lash on his newly built motor when we found the bolts that hold the rockers are pulling out and stripping the the threads on the head. There is not alot of bolt/thread holding the rockers to the head. There is room for longer bolts so he tapped the hole deeper and we installed longer grade-8 bolts and all is well. If that bolt lets loose, and the rocker comes off, its gonna make some racket and do some damage, so be aware and tap that hole and use longer bolts when changing out rockers......
_________________ If I can't Break it, it can't be Broke.............................
Fri Apr 30, 2010 11:54 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
Re: Heads Up-Pot. Problem with Briggs Heads!
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Sat May 01, 2010 9:00 am |
[ 2 posts ] |
Users browsing this forum: No registered users and 161 guests |
