It is currently Sat Jun 28, 2025 8:50 am
Reply to topic  [ 11 posts ]
 to shim or not to shim
Post to shim or not to shim
Dad has a 32 briggs. Having the heads ported and polished and the valves done. Also changed to the 36 carb. From everything I could gather, while working on the heads we should go ahead and shim the springs. Should we? If yes how many thousandths? Thanks.
Also, before the work he was turning around 4250 rpms when empty. He was using the wheel from a 27 and liked it because it planed out faster and carried a load a lot better. The valves were in pretty bad shape, so I'm assuming he should see some decent gains when he gets it back. I'm guessing he'll go back to the 32 prop, but should be close to 36 hp, so I'm guessing he'll be in the same rpm range. I knew pretty close to that range is where you are pretty close to floating the valves. So if it doesn't hurt anything to do it, I would think that we should. Just need to know how much.
Wed Jul 28, 2010 5:31 pm
Post Re: to shim or not to shim
Wed Jul 28, 2010 8:30 pm
Is it something we should do? Thanks man
Wed Jul 28, 2010 8:31 pm
Yes...I would!
Your valves generally begin to float in the 4350-4450 rpm range on these engines and you stated your already turning 4250. Working these heads (decking...porting/polishing)will allow you to turn higher rpm's....especially if you add an aftermarket carb. in the future.
Wed Jul 28, 2010 8:38 pm
Thanks again. Appreciate the explanation.
Wed Jul 28, 2010 8:39 pm
What sort of rpms is everyone running with carb/heads/exhaust?
I have the carb & exhaust and I'm debating about getting the heads. My dealer doesn't seem as impressed with heads as a lot of people on here and says it all depends on how well your current valves seat. He has consistently said that shimming the valves is a good and less expensive idea, if I'm bumping the rev limiter. I'm running 4150-4250 rpms now and only bump the limiter when grinding in the mud. Compression & leak-down tests are both fine.
I'm seriously considering the Iron Mountain heads because they seem reasonably priced with stainless steel valves included. Anyone have any opinions or suggestions about these?
Wed Jul 28, 2010 11:18 pm
Thu Jul 29, 2010 6:29 am
Thu Jul 29, 2010 10:39 am
These will help a lot, too:
Thu Jul 29, 2010 12:21 pm
May be a stupid question... But..
If you shim would you still set the valve clearance at .005? or does that change?
Sat Jul 31, 2010 5:47 pm
Set it the same, all the shim does is put more preload on the rocker so it don't float as quickly.
Sat Jul 31, 2010 6:31 pm
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 130 guests
