It is currently Sat Jun 28, 2025 12:13 pm
Reply to topic  [ 5 posts ]
 What kind of mods....
Post What kind of mods....
could be put on a gatortail 23hp that won't break the bank? Don't know much about the mods. Thanks guys.
Mon Aug 16, 2010 12:39 pm
Post Re: What kind of mods....
Define breaking the bank, that's kind of vague.
Mon Aug 16, 2010 1:05 pm
Mon Aug 16, 2010 2:27 pm
There is advantages to modding a motor vs buying a bigger motor and likewise advantages to having the bigger block vs modding the smaller one.
Modding the one you have, you will get a smoother powerband, better load capabilities, no more weight, and similar power to the big block.
Buying a new block, you get a motor that was designed to run with the parts it comes with, probably a warranty, ability to get a lot more power out of it if you chose to mod it down the road.
That being said, they have had really good luck with modding the 23's. You can get a lot of power out of those little forkers. Do a search for username filter and check out his ride. You can start small and do work as you have time and money. Rather than buying a bigger block out right. Depending on the size hull your running, weight could be a big determining factor.
Mon Aug 16, 2010 2:52 pm
Mon Aug 16, 2010 6:01 pm
Users browsing this forum: No registered users and 171 guests
