It is currently Sat Jun 28, 2025 12:46 pm
Reply to topic  [ 8 posts ]
 RELIABILTY WITH CAM
Post RELIABILTY WITH CAM
WAS WONDERING HOW RELIABLE IS THE 35 BRIGGS WITH THE AFTERMARKET CAM IN IT,IF ANYONE HAS HAD CAM FAILURE OR PROBLEM WITH THE HEADS AFTER INSTALLING NEW CAM
Sun Aug 22, 2010 9:58 am
Post Re: RELIABILTY WITH CAM
A friend and myself both bought cams from Hoyt and have had no issues at all. We both have over 150 and 200 hours on mods with no issues.
Sun Aug 22, 2010 11:27 am
A good cam is an awesome match wit heads. And da only cam failure I've ever seen was a stock cam on a completely stock motor. I also recomend Hoyt's cam.
Sun Aug 22, 2010 11:37 am
I have a BPS cam with heads and its doing really well for me. BPS cam is ground from a stock blank, not welded up but its not as aggressive as some of them out there.
Sun Aug 22, 2010 7:52 pm
MY evt cam failed after 2 hours , (one in the driveway one on the water)
I went with the bps and have done ok for another 30 or so hours until a lean conditon eat up a piston.
If you are doing a cam stay away from the roller rockers, I think the extra duration along with the higher lift is putting too much strain on the valve train.
along with shitty welding jops on the rebuilds. If you look back you will see quite a few cams breaking or going flat.
A buddy of mine has lots of hours on hoyts cam with no problems running stock pistons and rods along with a bps intake and a mukuni. His 16xd 60 gd sd boat with 35 hp gd sd is real fast, it jumps out of the hole and hits top speed of 31 or 32 in no time at all.
JD
Sun Aug 22, 2010 8:58 pm
Have a buddy with a MB45 (cam, rods, pistons, p-rods, roller rockers) over 220 hours. Rockers don't seem to put too much strain on the valve train.
Mon Aug 23, 2010 8:16 pm
will post results after installing cam, thanks for the input
Mon Aug 23, 2010 8:19 pm
QC was refering to me about the stock cam failing in a stock engine. I decided to upgrade while the repair is taking place. I went with Heads and a cam from Hoyt. I cannot trell you how it runs yet, but JC's motor sure impressed me. Hoyt also did Tchredneck's motor, and that prodrive is strong.
Tue Aug 24, 2010 6:16 am
Users browsing this forum: Google [Bot] and 168 guests
