It is currently Mon Jun 30, 2025 4:55 am
Reply to topic  [ 11 posts ]
 No lowend power on 35 gtr
Post No lowend power on 35 gtr
I recently had an issue with my carb. Had no power and would die when I gave it gas. Had the carb replaced. It now runs smooth but has no lowend. The prop will barely turn in the mud and I'm running a farely worn prop. As from a stop it doesnt rev up like it had previously. Should I have the carburater looked at or could I have another problem.
Sun Nov 21, 2010 11:23 am
Post Re: No lowend power on 35 gtr
def get the carb lookd at
Sun Nov 21, 2010 11:37 am
What was the issue with the original carb?
Mon Nov 22, 2010 5:17 am
It had no lowend power also but would die when I gave it gas. Not sure what was wrong with it. I took it in and he said he replaced it under warranty. So I'm guessing it was more than just needing a cleaning.
I can take back too him if I have to but I would like to try and figure it out myself if I can. I need to learn how to work on carbs anyways.
Mon Nov 22, 2010 5:23 am
Broz....how many hours on the engine? Have you ALWAYS had this problem? What hull is the engine on?
Mon Nov 22, 2010 7:43 am
It's got about 90 hours. It's on a nex 1854 extreme. The problem has recently developed. It ran like a champ thru the summer and starting acting up a couple weeeks ago. Replaced carb and it is idling, running smooth but just doesn't have the power. When I give it gas it starts out strong for a second then seems to lose power till it hits higher rpm's. It still climbs up in rpm's but slowly. And like I said, if in the mud it will move the boat but doesn't get it on step due to the low rpm's. But it worked great prior to these issues.
Mon Nov 22, 2010 8:39 am
It could be one od several things....i'd check valve lash and also perform a leak down test.
Mon Nov 22, 2010 8:52 am
I'm waiting on the shop to give me a call back. I asked them to do a compression check and adjust the valves when they replaced the carb so I'm sure they did. I've been reading thru posts and I'm thinking the carb might just need some adjusting. When they call me back I guess I'll have a better idea what's going on.
Where can I get some good instructions on how to setup the carb. I'm mechanically inclined and confident I could do it. But I'm from the generation of fuel injection. Never torn a carb apart.
Mon Nov 22, 2010 9:00 am
The carb is pretty much set as is.....only thing needing adjusting is your idle jets and that isn't gonna cause you the issues your experiencing.
Mon Nov 22, 2010 9:03 am
Alright. Well I be waiting to talk to the shop and see what they had to say about the comp. test.
Mon Nov 22, 2010 9:12 am
Could they have set the valve lash wrong and it flatten a cam lobe?
Mon Nov 22, 2010 9:15 am
Users browsing this forum: No registered users and 119 guests
