It is currently Tue Sep 16, 2025 2:24 pm
Reply to topic  [ 15 posts ]
 F Y I
Post F Y I
I just wanted to put this out there for you guys.
The other day I noticed my engine ( GTR 35 w/ cam, heads, carb work and 235hrs ) felt a lil slugish getting out the hole and when i was in the thick sheet.
When I got it home i did a leak down on the cylinders and found my intake valves were leaking. I took the engine down and lapped the valves. When I got it in the water It was a night and day difference. I didnt realize how much power I had lost.
So any way i just wanted to share that with everybody. Its something to think about if anyone as noticed a power loss
BUCK OFAMA
Tue Mar 31, 2009 8:21 pm
Post Re: F Y I
And also now the damn thing wants to role up to 4600 rpms as compared to the previous 4400rpms
BUCK OFAMA
Tue Mar 31, 2009 8:23 pm
Post Re: F Y I
17x48 extreme stage 2 GTR
Tue Mar 31, 2009 8:26 pm
Post Re: F Y I
Pal I would have got you last time if my gov hadnt been bumpin in at 4350. i was on your ass wit the wife and kid. :D
BUCK OFAMA
Tue Mar 31, 2009 8:32 pm
Post Re: F Y I
Tue Mar 31, 2009 8:34 pm
Post Re: F Y I
Wed Apr 01, 2009 4:52 am
Post Re: F Y I
no rpm loss just low end power lost.
It dosent matter who did the heads, Its a 3600 rpm engine turning 1000rpms over its desigened rpm range with stock valves. Something has to give ya know.This kind of thing is not uncommon when getting more HP out of a engine than what was intended. It was no ones fault, it wasnt the person who done the heads, it just happens. Im just a mechanic by trade who knew whaqt to look for with access to good test tools, thats all. I just want this info to help someone else if needed. And Im not saying that this will happen to every engine!!!!!
abouot 200 hard hours on the heads.
It dosent surprise at all. I have to change the valves in my four wheeler every 100 hours for the same reason. but it turns 11,000 rpms.
BUCK OFAMA
Wed Apr 01, 2009 9:14 pm
Post Re: F Y I
Can the leak down test done by who ??
Elaborate on this procedure ... infin you don't mind. :?:
Wed Apr 01, 2009 9:17 pm
Post Re: F Y I
A leak down test is when you check how much leakage you have in a cylinder. Its a tool thats preasures up the cylinder while the valves are closed and at the same time it tells you a percentage of how much of the volume of air is getting out the cylinder. If the percentage is low like 15-20% your good. Mine were both around 60% and you could hear the air blowing out the intake manifold at a high rate while doing the test. Inturn telling me it was the intake valves leaking. You can not do the test without a leak down tester, the proper connectors and a air compressor.
The leak down will tell you if you valves are bad or if your rings/cylinder are bad.
BUCK OFAMA
Wed Apr 01, 2009 9:29 pm
Post Re: F Y I
Thu Apr 02, 2009 1:38 pm
Post Re: F Y I
Im not a motor guy, so are there any other things to look for?
I lost some power, one plug is wet, and my exsaust is turnng black....it this leaking valves.
James
Thu Apr 02, 2009 2:54 pm
Post Re: F Y I
Freedom It Wasn't Free!!!
It Was Won!!!
Enjoy It!!!
The more you try to teach a stupid person something the dumber you get!!!
Thu Apr 02, 2009 3:00 pm
Post Re: F Y I
BUCK OFAMA
Thu Apr 02, 2009 5:52 pm
Post Re: F Y I
BUCK OFAMA
Thu Apr 02, 2009 5:55 pm
Post Re: F Y I
Got the gap at 30 and it just started about 5 hrs ago.....
Only thing that has haend is I droed 4 bolts....
Its all good I'm takn it in next week to get operated on.....
Ill let ya know.
Later
Thu Apr 02, 2009 8:05 pm
